New cargo solution for your Ford - Cargo Ease Bed Slide and Cargo Crane
Discussion in 'CARiD.com' started by carid, Sep 28, 2018.
    If you move and load heavy objects onto your truck bed and your back is already begging for some rest we have something interesting for you. Build your Ford into an ultimate helper with Cargo Ease Products! When you need to grab hard to reach objects and load or unload different items, bed slides will make this process a breeze for you. In case you need to haul an engine to the shop, load a bunch of cinder blocks or something heavier, using a cargo crane will get this job done for you. Combine them together and you'll get the best cargo carrying solution ever!
    Cargo Ease Cargo Crane at CARiD
    Features:
    - Universal hitch crane
    - 750 lbs lift capacity
    - Uses standard class 3 trailer hitch with a tongue weight rating of 500lbs +
    - Ramps attached to frame
    - Adjustable cranes Left & Right
    - Comes with a hand brake winch and does not block the tail gate.
    Cargo Ease Bed Slide at CARiD.com
    Features:
    - Allows for up to 70% extension
    - Powder coated steel frames for added safety
    - Aluminum side rails for added safety
    - Plywood deck with a synthetic carpet
    - Spring release T-handle regulates cargo load space
    - Sealed roller bearings for improved reliability
    - 3 locking positions – in, half-way out, and fully extended
    - Tough linkage lock mechanism
    - Comes fully assembled.
    Navigate here for all Cargo Ease Bed Slides & Truck Accessories
    Maximize the cargo carrying capabilities of your truck with Cargo Ease Products!​
