Im assuming shocks cause it sounds like your shaking a chainlink fence under the truck when you run bumps. Edit, tested shocks, they seem fine.. creeking & ricketing from the front passenger when you rock on it, sounds like a fence when you drive though. Sent from my SPH-L710 using Tapatalk 2
unfortunately it sounds like your ball joints are going out. i have the same problem with mine. i'm waiting till it gets warmer to do mine.
fence creek is typical of a balljoint that is low/out of grease. and you have a UPPER ball joint on the Upper Control arm (entire assembly needs to be replaced for that swap), you have a tie rod ball joint (more than likely what the dealer swapped), and you have a Lower Ball Joint located on the Lower Control arm (this will need to be pressed out, goodyear is inexpensive and good at this).
Checked it out more, the control arm bushing for my shock decided it didn't like me anymore lol. Going to replace the bushing instead of buyin new shocks Rancho 9000s vs bilsteins anyone? Also, when yall goin & where? Id love a trip with y'all, just need to make sure I have the cash! & ill be at the joint tomorrow night! Sent from my SPH-L710 using Tapatalk 2
Lol, I can definstely try them. Ive loved my ranchos, always done me good Sent from my SPH-L710 using Tapatalk 2
