New guy needing help
Discussion in 'Engine & Performance' started by jamestaylor47, Jan 6, 2013.
  1. Roush PSD Interceptor
    Would be good to know the fuel pressure at both points.
    Heard those 2004 5.4 up don't have a Schrader valve on the fuel rail.
    Needs a specific "T" fitting that is in some fuel pressure testing kits.
    So I have heard.
  2. jamestaylor47
    jamestaylor47 Junior Member
    Oklahoma
    Well ill change the plugs tonight see if that helps if not put a filter on it then go from tere
    Tap Tap
  3. Roush PSD Interceptor
    It wouldn't hurt to check the compression while the plugs are out
    if ya have resources to a compression tester.
  4. Big'un
    sounds like it needs all new COP and plugs
  5. jamestaylor47
    Oklahoma
    Cop?
    Tap Tap
  6. cowboy
    coil over plug
  7. Summitrider2012
    Summitrider2012 Junior Member
    Nh
    Sounds like the fuel sending unit maybe if it has b 1 and 2 lean. Not enough fuel equals lean my 2 cents
