New guy to this forum with 2000 f150
Discussion in 'General Discussions' started by 2thousand5four, Jul 16, 2015.
  1. 2thousand5four
    2thousand5four Full Access Member
    Virginia
    Rear pads and front and rear rotors should be here tommorow
  2. Shaggy
    Arizona
    How bad were the pads and rotors?
  3. 2thousand5four
    Virginia
    The front ones where worn down a good bit past the recommended wear mark, I haven't taken the rears off yet but I'll take pics when I do.
  4. 2thousand5four
    Virginia
    Ups guy didn't show up till almost 8 so I didn't get a chance to do anything :/ hopefully I will have time tomorrow
  5. 2thousand5four
    Virginia
    Rear rotors looked fine so I'm gonna return the new rear rotors. The pads on the other hand were bad. 3 were past the wear mark and the forth you could just barely see the wear mark
    [​IMG][​IMG]
  6. 2thousand5four
    Virginia
    Well my tailgate was squeaking when I went over bumps so I ordered a new bushing kit and that came in today. It was raining so I took the tailgate off the truck to change the bushings. Well, a simple 5 minute bushing change turned into a full on 3 hour detail session. I ended up washing it then using a heavy rubbing compound, then a medium light compound, then a swirl remover/Polish, then another wash, clay bar, mirror glaze, then waxed it. Tailgate looks soooo much better now. uploadfromtaptalk1447122852339.jpg [​IMG] It still has a lot of paint chips so I ordered a touch up pen to take care of those. uploadfromtaptalk1447122879176.jpg [​IMG][​IMG] I also peeled the white plasti dip off the tailgate handle and sprayed it white with real paint this time. [​IMG]
  7. ak_cowboy
    Looks great!
  8. 2thousand5four
    Virginia
    Thanks! should be a lot better once I fix those paint chips
  9. 2thousand5four
    Virginia
    Well turns out krylon white looks like yellow when it's beside oxford white. I have some oxford white spray paint coming in tommorow so I'll redo the handle again tomorrow
  10. 2thousand5four
    Virginia
    Tailgate is Much better now. I'll get some daylight picks tommorow uploadfromtaptalk1447631880139.jpg uploadfromtaptalk1447631894277.jpg [​IMG]
