New here from south Texas!
Discussion in 'Introduction' started by 03fx4, Jan 16, 2014.
  1. str8t six
    str8t six never enough
    Back in VA
    welcome to the forum!
    looks like you got a pretty good deal!
    atleast the interior is easy to clean up!
    :welcome:
  3. Roush PSD Interceptor
    :welcome:
    The defrost only mode could be a broken vacuum line behind the
    engine starting battery.
    May also still be a bad EATC vacuum control module.
    Removing the module and testing the lines with a vacuum pump
    will diagnose this. The center vacuum line should be draw from the
    engine and the other lines are the different options for air control.
    Saw this trick for making a smoke pump to diagnose vacuum hose leaks.
    Checking for vacuum leaks using home made smoke pump. - YouTube
    Aquarium air pump or manual air pump for air matress could substitute
    for the electric pump.
    If ya find it is the EATC maybe a repair service like this would help.
    http://circuitboardmedics.com/ford-eatc-electronic-automatic-temperature-control-repair/
  4. Shaggy
    Arizona
    Nice pick up! Hell of a deal. How did you find us here at FFS.com? :)
  5. 03fx4
    03fx4 Full Access Member
    Thanks, I searched tapatalks database and clicked on several f150 sites but this one looked like it had more/better info.
  6. b00std
    b00std Member
    SATX
    :welcome:
    I'm no good at e-troubleshooting, but it it possibly a bearing that's going out?
