OBD II codes
Pity7700
oh umm...uhh?
Age
Thought this might be a helpful thread. I have a ton more.
P01XX Fuel and Air Metering
1. P0100- Mass or volume airflow circuit malfunction.
2. P0101- Mass or volume airflow circuit range/performance problem
3. P0102- Mass or volume airflow circuit low input
4. P0103- Mass or volume airflow circuit high input
5. P0104- Mass or volume airflow circuit intermittent
6. P0105- Manifold absolute pressure/barometric pressure circuit malfunction
7. P0106- Manifold absolute pressure/barometric pressure circuit range/performance problem
8. P0107- Manifold absolute pressure/barometric pressure circuit low input
9. P0108- Manifold absolute pressure/barometric pressure circuit high input
10. P0109- Manifold absolute pressure/barometric pressure circuit intermittent
11. P0110- Intake air temperature circuit malfunction
12. P0111- Intake air temperature circuit range/performance problem
13. P0112- Intake air temperature circuit low input
14. P0113- Intake air temperature circuit high input
15. P0114- Intake air temperature circuit low input
16. P0115- Engine Coolant temperature circuit malfunction
17. P0116- Engine coolant temperature circuit range/performance problem
18. P0117- Engine coolant temperature circuit low input
19. P0118- Engine coolant temperature circuit high input
20. P0119- Engine coolant temperature circuit intermittent
21. P0120- Throttle/pedal position sensor/switch A circuit malfunction
22. P0121- Throttle/pedal position sensor/switch A circuit range/performance problem
23. P0122- Throttle/pedal position sensor/switch A circuit low input
24. P0123- Throttle/pedal position sensor/switch A circuit high input
25. P0124- Throttle/pedal position sensor/switch A circuit intermittent
26. P0125- Insufficient coolant temperature for closed loop fuel control
27. P0126- Insufficient coolant temperature for stable operation
28. P0130- Oxygen sensor circuit malfunction (bank 1 sensor 1)
29. P0131- Oxygen sensor circuit low voltage (bank 1 sensor 1)
30. P0132- Oxygen sensor circuit high voltage (bank 1 sensor 1)
31. P0133- Oxygen sensor circuit slow response (bank 1 sensor 1)
32. P0134- Oxygen sensor circuit no activity detected (bank 1 sensor 1)
33. P0135- Oxygen sensor heater circuit malfunction (bank 1 sensor 1)
34. P0136- Oxygen sensor circuit malfunction (bank 1 sensor 2)
35. P0137- Oxygen sensor circuit low voltage (bank 1 sensor 2)
36. P0138- Oxygen sensor circuit high voltage (bank 1 sensor 2)
37. P0139- Oxygen sensor circuit slow response (bank 1 sensor 2)
38. P0140- Oxygen sensor circuit no activity detected (bank 1 sensor 2)
39. P0141- Oxygen sensor heater circuit malfunction (bank1 sensor 2)
40. P0142- Oxygen sensor circuit malfunction (bank 1 sensor 3)
41. P0143- Oxygen sensor circuit low voltage (bank 1 sensor 3)
42. P0144- Oxygen sensor circuit high voltage (bank 1 sensor 3)
43. P0145- Oxygen sensor circuit slow response (bank 1 sensor 3)
44. P0146- Oxygen sensor circuit no activity detected (bank 1 sensor 3)
45. P0147- Oxygen sensor heater circuit malfunction (bank 1 sensor 3)
46. P0150- Oxygen sensor circuit malfunction (bank 2 sensor 1)
47. P0151- Oxygen sensor circuit low voltage (bank 2 sensor 1)
48. P0152- Oxygen sensor circuit high voltage (bank 2 sensor 1)
49. P0153- Oxygen sensor circuit slow response (bank 2 sensor 1)
50. P0154- Oxygen sensor circuit no activity detected (bank 2 sensor 1)
51. P0155- Oxygen sensor heater circuit malfunction (bank 2 sensor 1)
52. P0156- Oxygen sensor circuit malfunction (bank 2 sensor 1)
53. P0157- Oxygen sensor circuit low voltage (bank 2 sensor 2)
54. P0158- Oxygen sensor circuit high voltage (bank 2 sensor 2)
55. P0159- Oxygen sensor circuit slow response (bank 2 sensor 2)
56. P0160- Oxygen sensor circuit no activity detected (bank 2 sensor 1)
57. P0161- Oxygen sensor heater circuit malfunction (bank2 sensor 2)
58. P0162- Oxygen sensor circuit malfunction (bank 2 sensor 2)
59. P0163- Oxygen sensor circuit low voltage (bank 2 sensor 3)
60. P0164- Oxygen sensor circuit high voltage (bank 2 sensor 3)
61. P0165- Oxygen sensor circuit slow response (bank 2 sensor 3)
62. P0166- Oxygen sensor circuit no activity detected (bank 2 sensor 3)
63. P0167- Oxygen sensor heater circuit malfunction (bank 2 sensor 3)
64. P0170- Fuel trim malfunction (bank 1)
65. P0171- System too lean (bank 1)
66. P0172- System too rich (bank 1)
67. P0173- Fuel trim malfunction (bank 2)
68. P0174- System too lean (bank 2)
69. P0175- System too rich (bank 2)
70. P0176- Fuel composition sensor circuit malfunction
71. P0177- Fuel composition sensor circuit range/performance
72. P0178- Fuel composition sensor circuit low input
73. P0179- Fuel composition sensor circuit high input
74. P0180- Fuel temperature sensor A circuit malfunction
75. P0181- Fuel temperature sensor A circuit range/performance
76. P0182- Fuel temperature sensor A circuit low input
77. P0183- Fuel temperature sensor A circuit high input
78. P0184- Fuel temperature sensor A circuit intermittent
79. P0185- Fuel temperature sensor B circuit Malfunction
80. P0186- Fuel temperature sensor B circuit range/performance
81. P0187- Fuel temperature sensor B circuit low input
82. P0188- Fuel temperature sensor B circuit high input
83. P0189- Fuel temperature sensor B circuit intermittent
84. P0190- Fuel rail pressure sensor circuit malfunction
85. P0191- Fuel rail pressure sensor circuit range/performance
86. P0192- Fuel rail pressure sensor circuit low input
87. P0193- Fuel rail pressure sensor circuit high input
88. P0194- Fuel rail pressure sensor circuit intermittent
89. P0195- Engine oil temperature sensor malfunction
90. P0196- Engine oil temperature sensor range/performance
91. P0197- Engine oil temperature sensor low
92. P0198- Engine oil temperature sensor high
93. P0199- Engine oil temperature sensor intermittent
They are generic SAE codes and my Electrics book doesnt tell me specific years. the book is brand new copyright 2010. so any vehicle up to 2010 is what im going to say. i also have P02XX fuel and air metering, P03XX ignition system or misfire, P04XX auxiliary emission controls, P05XX vehicle speed, idle control, and aux. inputs, P06XX computer and aux outputs and P07XX transmission.
Haha good job bigun!
Pity - How did you get all that sweet equipment?
hahaha im in school for automotive and right now im doing all my auto electrics, hopefully becoming ASE certified in auto electrics and suspension and steering after next semester.
its all in my book along with resistor values and conversion charts, SAE abbreviations, electrical symbols and loads of other really good stuff. i know some diagnostic procedures as well like parasitic load tests, dirty battery test, post/terminal tests and others. im falling in love with auto electrics
Wow, I'm glad there are people in this world like you, cuz that stuff puts me to sleep
P02xx
PO2XX Fuel and Air Metering
P0200-Injector circuit malfunction
P0201-Injector circuit-cylinder 1
P0202-Injector circuit-cylinder 2
P0203-Injector circuit-cylinder 3
P0204-Injector circuit-cylinder 4
P0205-Injector circuit-cylinder 5
P0206-Injector circuit-cylinder 6
P0207-Injector circuit-cylinder 7
P0208-Injector circuit-cylinder 8
P0209-Injector circuit-cylinder 9
P0210-Injector circuit-cylinder 10
P0211-Injector circuit-cylinder 11
P0212-Injector circuit-cylinder 12
P0213-Cold start injector 1 malfunction
P0214-Cold start injector 2 malfunction
P0215-Engine shutoff solenoid malfunction
P0216-Injection timing control circuit malfunction
P0217-Engine over temperature condition
P0218-Transmission over temperature condition
P0219-Engine over speed condition
P0220-Throttle/pedal position sensor/switch B circuit malfunction
P0221-Throttle/pedal position sensor/switch B circuit range/performance problem
P0222-Throttle/pedal position sensor/switch B circuit low input
P0223-Throttle/pedal position sensor/switch B circuit high input
P0224-Throttle/pedal position sensor/switch B circuit intermittent
P0225-Throttle/pedal position sensor/switch C circuit malfunction
P0226-Throttle/pedal position sensor/switch C circuit range/performance problem
P0227-Throttle/pedal position sensor/switch C circuit low input
P0228-Throttle/pedal position sensor/switch C circuit high input
P0229-Throttle/pedal position sensor/switch C circuit intermittent
P0230-Fuel pump primary circuit malfunction
P0231-Fuel pump secondary circuit low
P0232-Fuel pump secondary circuit high
P0233-Fuel pump secondary circuit intermittent
P0235-Turbocharger boost sensor A circuit malfunction
P0236-Turbocharger boost sensor A circuit range/performance
P0237-Turbocharger boost sensor A circuit low
P0238-Turbocharger boost sensor A circuit high
P0239-Turbocharger boost sensor B circuit malfunction
P0240-Turbocharger boost sensor B circuit range/performance
P0241-Turbocharger boost sensor B circuit low
P0242-Turbocharger boost sensor B circuit high
P0243-Turbocharger wastegate solenoid A malfunction
P0244-Turbocharger wastegate solenoid A range/performance
P0245-Turbocharger wastegate solenoid A low
P0246-Turbocharger wastegate solenoid A high
P0247-Turbocharger wastegate solenoid B malfunction
P0248-Turbocharger wastegate solenoid B range/performance
P0249-Turbocharger wastegate solenoid B low
P0250-Turbocharger wastegate solenoid B high
P0251-Injection pump A rotor/cam malfunction
P0252-Injection pump A rotor/cam range/performance
P0253-Injection pump A rotor/cam low
P0254-Injection pump A rotor/cam high
P0255-Injection pump A rotor/cam intermittent
P0256-Injection pump B rotor/cam malfunction
P0257-Injection pump B rotor/cam range/performance
P0258-Injection pump B rotor/cam low
P0259-Injection pump B rotor/cam high
P0260-Injection pump B rotor/cam intermittent
P0261-Cylinder 1 injector circuit low
P0262-Cylinder 1 injector circuit high
P0263-Cylinder 1 contribution/balance fault
P0264-Cylinder 2 injector circuit low
P0265-Cylinder 2 injector circuit high
P0266-Cylinder 2 contribution/balance fault
P0267-Cylinder 3 injector circuit low
P0268-Cylinder 3 injector circuit high
P0269-Cylinder 3 contribution/balance fault
P0270-Cylinder 4 injector circuit low
P0271-Cylinder 4 injector circuit high
P0272-Cylinder 4 contribution/balance fault
P0273-Cylinder 5 injector circuit low
P0274-Cylinder 5 injector circuit high
P0275-Cylinder 5 contribution/balance fault
P0276-Cylinder 6 injector circuit low
P0277-Cylinder 6 injector circuit high
P0278-Cylinder 6 contribution/balance fault
P0279-Cylinder 7 injector circuit low
P0280-Cylinder 7 injector circuit high
P0281-Cylinder 7 contribution/balance fault
P0282-Cylinder 8 injector circuit low
P0283-Cylinder 8 injector circuit high
P0284-Cylinder 8 contribution/balance fault
P0285-Cylinder 9 injector circuit low
P0286-Cylinder 9 injector circuit high
P0287-Cylinder 9 contribution/balance fault
P0289-Cylinder 10 injector circuit low
P0290-Cylinder 10 injector circuit high
P0291-Cylinder 10 contribution/balance fault
P0292-Cylinder 11 injector circuit low
P0293-Cylinder 11 injector circuit high
P0294-Cylinder 11 contribution/balance fault
P0295-Cylinder 12 injector circuit low
P0296-Cylinder 12 injector circuit high
P0297-Cylinder 12 contribution/balance fault
