OBD II codes
Discussion in 'Tech Info' started by Pity7700, Nov 28, 2010.
  1. BuckChucklestik
    BuckChucklestik Junior Member
    YES!!! Thank you! That will certainly cut down on the what does P0XXX code mean! Putting helpful information like this in a permanent spot (like a sticky) is the smartest thing a truck support forum can do.
  2. Pity7700
    Yea! I've got a lot more to put up, ill try to get to it this week.
  3. twin
    twin bamf president
    small town USA
    hell yea!!! good job!!!
    i have the programmer and it tells me what code number and explains what it is
  4. Pity7700
    P03xx
    P03xx Ignition system or misfire
    P0300-Random/multiple cylinder misfire detected
    P0301-Cylinder 1 misfire detected
    P0302-Cylinder 2 misfire detected
    P0303-Cylinder 3 misfire detected
    P0304-Cylinder 4 misfire detected
    P0305-Cylinder 5 misfire detected
    P0306-Cylinder 6 misfire detected
    P0307-Cylinder 7 misfire detected
    P0308-Cylinder 8 misfire detected
    P0309-Cylinder 9 misfire detected
    P0310-Cylinder 10 misfire detected
    P0311-Cylinder 11 misfire detected
    P0312-Cylinder 12 misfire detected
    P0320-Ignition/distributor engine speed input circuit malfunction
    P0321-Ignition/distributor engine speed input circuit range/performance
    P0322-Ignition/distributor engine speed input circuit no signal
    P0324-Ignition/distributor engine speed input circuit intermittent
    P0325-Knock sensor 1 circuit malfunction (bank 1 or single sensor)
    P0326-Knock sensor 1 circuit range/performance (bank 1 or single sensor)
    P0327-Knock sensor 1 circuit low input (bank 1 or single sensor)
    P0328-Knock sensor 1 circuit high input (bank 1 or single sensor)
    P0329-Knock sensor 1 circuit intermittent (bank 1 or single sensor)
    P0330-Knock sensor 2 circuit malfunction (bank 2)
    P0331-Knock sensor 2 circuit range/performance (bank 2)
    P0332-Knock sensor 2 circuit low input (bank 2)
    P0333-Knock sensor 2 circuit high input (bank 2)
    P0334-Knock sensor 2 circuit intermittent (bank 2)
    P0335-Crankshaft position sensor A circuit malfunction
    P0336-Crankshaft position sensor A circuit range/performance
    P0337-Crankshaft position sensor A circuit low input
    P0338-Crankshaft position sensor A circuit high input
    P0339-Crankshaft position sensor A circuit intermittent
    P0340-Camshaft position sensor circuit malfunction
    P0341-Camshaft position sensor circuit range/performance
    P0342-Camshaft position sensor circuit low input
    P0343-Camshaft position sensor circuit high input
    P0344-Camshaft position sensor circuit intermittent
    P0350-Ignition coil primary/secondary circuit malfunction
    P0351-ignition coil A primary/secondary circuit malfunction
    P0352-Ignition coil B primary/secondary circuit malfunction
    P0353-Ignition coil C primary/secondary circuit malfunction
    P0354-Ignition coil D primary/secondary circuit malfunction
    P0355-Ignition coil E primary/secondary circuit malfunction
    P0356-Ignition coil F primary/secondary circuit malfunction
    P0357-Ignition coil G primary/secondary circuit malfunction
    P0358-Ignition coil H primary/secondary circuit malfunction
    P0359-Ignition coil I primary/secondary circuit malfunction
    P0360-Ignition coil J primary/secondary circuit malfunction
    P0361-Ignition coil K primary/secondary circuit malfunction
    P0362-Ignition coil L primary/secondary circuit malfunction
    P0370-Timing reference high resolution signal A malfunction
    P0371-Timing reference high resolution signal A too many pulses
    P0372-Timing reference high resolution signal A too few pulses
    P0373-Timing reference high resolution signal intermittent/erratic pulses
    P0374-Timing reference high resolution signal A no pulses
    P0375-Timing reference high resolution signal B malfunction
    P0376-Timing reference high resolution signal B too many pulses
    P0377-Timing reference high resolution signal B too few pulses
    P0378-Timing reference high resolution signal B intermittent/erratic pulses
    P0379-Timing reference high resolution signal B no pulse
    P0380-Glow plug/Heater circuit malfunction
    P0381-Glow plug/heater indicator circuit malfunction
    P0385-Crankshaft position sensor B circuit malfunction
    P0386-Crankshaft position sensor B range/performance
    P0387-Crankshaft position sensor B low input
    P0388-Crankshaft position sensor B high input
    P0389-Crankshaft position sensor B circuit intermittent
  5. Pity7700
    P04xx
    P04XX Auxiliary Emission Controls
    P0400-Exhaust gas recirculation flow malfunction
    P0401-Exhaust gas recirculation flow insufficient detected
    P0402-Exhaust gas recirculation flow excessive detected
    P0403-Exhaust gas recirculation circuit malfunction
    P0404-Exhaust gas recirculation range/performance
    P0405-Exhaust gas recirculation sensor A circuit low
    P0406-Exhaust gas recirculation sensor A circuit high
    P0407-Exhaust gas recirculation sensor B circuit low
    P0408-Exhaust gas recirculation sensor B circuit high
    P0410-Secondary air injection system malfunction
    P0411-Secondary air injection system incorrect flow detected
    P0412-Secondary air injection system switching valve A circuit malfunction
    P0413-Secondary air injection system switching valve A circuit open
    P0414-Secondary air injection system switching valve A circuit shorted
    P0415-Secondary air injection system switching valve B circuit malfunction
    P0416-Secondary air injection system switching valve B circuit open
    P0417-Secondary air injection system switching valve B circuit shorted
    P0420-Catalyst system efficiency below threshold (bank 1)
    P0421-Warm up catalyst efficiency below threshold (bank 1)
    P0422-Main catalyst efficiency below threshold (bank 1)
    P0423-Heated catalyst efficiency below threshold (bank 1)
    P0424-Heated catalyst temperature below threshold (bank 1)
    P0430-Catalyst efficiency below threshold (bank 2)
    P0431-Warm up catalyst efficiency below threshold (bank 2)
    P0432-Main catalyst efficiency below threshold (bank 2)
    P0433-Heated catalyst efficiency below threshold (bank 2)
    P0434-Heated catalyst temperature below threshold (bank 2)
    P0440-Evaporative emission control system malfunction
    P0441-Evaporative emission control system incorrect purge flow
    P0442-Evaporative emission control system leak detected (small leak)
    P0443-Evaporative emission control system purge control valve circuit malfunction
    P0444-Evaporative emission control system purge control valve circuit open
    P0445-Evaporative emission control system purge control valve circuit shorted
    P0450-Evaporative emission control system pressure sensor malfunction
    P0451-Evaporative emission control system pressure sensor range/performance
    P0452-Evaporative emission control system pressure sensor low input
    P0453-Evaporative emission control system pressure sensor high input
    P0454-Evaporative emission control system pressure sensor intermittent
    P0455-Evaporative emission control system leak detected (gross leak)
    P0460-Fuel level sensor circuit malfunction
    P0461-Fuel level sensor circuit range/performance
    P0462-Fuel level sensor circuit low input
    P0463-Fuel level sensor circuit high input
    P0464-Fuel level sensor circuit intermittent
    P0465-Purge flow sensor circuit malfunction
    P0466-Purge flow sensor circuit range/performance
    P0467-Purge flow sensor circuit low input
    P0468-Purge flow sensor circuit high input
    P0469-Purge flow sensor circuit intermittent
    P0470-Exhaust pressure sensor malfunction
    P0471-Exhaust pressure sensor range/performance
    P0472-Exhaust pressure sensor low
    P0473-Exhaust pressure sensor high
    P0474-Exhaust pressure sensor intermittent
    P0475-Exhaust pressure control valve malfunction
    P0476-Exhaust pressure control valve range/performance
    P0477-Exhaust pressure control valve low
    P0478-Exhaust pressure control valve high
    P0479-Exhaust pressure control valve intermittent
  6. Roush PSD Interceptor
    P0480-Cooling Fan I Control Circuit Malfunction
    P0481-Cooling Fan 2 Control Circuit Malfunction
    P0482-Cooling Fan 3 Control Circuit Malfunction
    P0483-Cooling Fan Rationality Check Malfunction
    P0484-Cooling Fan Circuit Over Current
    P0485-Cooling Fan Power/Ground Circuit MalfunctionP0500-Vehicle Speed Sensor Malfunction
    P0501-Vehicle Speed Sensor Range/Performance
    P0502-Vehicle Speed Sensor Low Input
    P0503-Vehicle Speed Sensor Intermittent/Erratic/High
    P0505-Idle Control System Malfunction
    P0506-Idle Control System RPM Lower Than Expected
    P0507-Idle Control System RPM Higher Than Expected
    P0510-Closed Throttle Position Switch Malfunction
    P0520-Engine Oil Pressure Sensor/Switch Circuit Malfunction
    P0521-Engine Oil Pressure Sensor/Switch Circuit Range/Performance
    P0522-Engine Oil Pressure Sensor/Switch Circuit Low Voltage
    P0523-Engine Oil Pressure Sensor/Switch Circuit High Voltage
    P0530-A/C Refrigerant Pressure Sensor Circuit Malfunction
    P0531-A/C Refrigerant Pressure Sensor Circuit Range/Performance
    P0532-A/C Refrigerant Pressure Sensor Circuit Low Input
    P0533-A/C Refrigerant Pressure Sensor Circuit High Input
    P0534-Air Conditioner Refrigerant Charge Loss
    P0550-Power Steering Pressure Sensor Circuit Malfunction
    P0551-Power Steering Pressure Sensor Circuit Range/Performance
    P0552-Power Steering Pressure Sensor Circuit Low Input
    P0553-Power Steering Pressure Sensor Circuit High Input
    P0554-Power Steering Pressure Sensor Circuit Intermittent
    P0560-System Voltage Malfunction
    P0561-System Voltage Unstable
    P0562-System Voltage Low
    P0563-System Voltage High
    P0565-Cruise Control On Signal Malfunction
    P0566-Cruise Control Off Signal Malfunction
    P0567-Cruise Control Resume Signal Malfunction
    P0568-Cruise Control Set Signal Malfunction
    P0569-Cruise Control Coast Signal Malfunction
    P0570-Cruise Control Accel Signal Malfunction
    P0571-Cruise Control/Brake Switch A Circuit Malfunction
    P0572-Cruise Control/Brake Switch A Circuit Low
    P0573-Cruise Control/Brake Switch A Circuit High
    P0574-Cruise Control Related Malfunction
    P0575-Cruise Control Related Malfunction
    P0576-Cruise Control Related Malfunction
    P0578-Cruise Control Related Malfunction
    P0579-Cruise Control Related Malfunction
    P0580-Cruise Control Related Malfunction
  7. Roush PSD Interceptor
    P0600-Serial Communication Link Malfunction
    P0601-Internal Control Module Memory Check Sum Error
    P0602-Control Module Programming Error
    P0603-Internal Control Module Keep Alive Memory (KAM) Error
    P0604-Internal Control Module Random Access Memory (RAM) Error
    P0605-Internal Control Module Read Only Memory (ROM) Error
    P0606-PCM Processor Fault
    P0608-Control Module VSS Output "A" Malfunction
    P0609-Control Module VSS Output "B" Malfunction
    P0610-Control Module Vehicle Options Error
    P0620-Generator Control Circuit Malfunction
    P0621-Generator Lamp "L" Control Circuit Malfunction
    P0622-Generator Field "F" Control Circuit Malfunction
    P0650-Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
    P0654-Engine RPM Output Circuit Malfunction
    P0655-Engine Hot Lamp Output Control Circuit Malfunction
    P0656-Fuel Level Output Circuit Malfunction
    P0700-Transmission Control System Malfunction
    P0701-Transmission Control System Range/Performance
    P0702-Transmission Control System Electrical
    P0703-Torque Converter/Brake Switch B Circuit Malfunction
    P0704-Clutch Switch Input Circuit Malfunction
    P0705-Transmission Range Sensor Circuit malfunction (PRNDL Input)
    P0706-Transmission Range Sensor Circuit Range/Performance
    P0707-Transmission Range Sensor Circuit Low Input
    P0708-Transmission Range Sensor Circuit High Input
    P0709-Transmission Range Sensor Circuit Intermittent
    P0710-Transmission Fluid Temperature Sensor Circuit Malfunction
    P0711-Transmission Fluid Temperature Sensor Circuit Range/Performance
    P0712-Transmission Fluid Temperature Sensor Circuit Low Input
    P0713-Transmission Fluid Temperature Sensor Circuit High Input
    P0714-Transmission Fluid Temperature Sensor Circuit Intermittent
    P0715-Input/Turbine Speed Sensor Circuit Malfunction
    P0716-Input/Turbine Speed Sensor Circuit Range/Performance
    P0717-Input/Turbine Speed Sensor Circuit No Signal
    P0718-Input/Turbine Speed Sensor Circuit Intermittent
    P0719-Torque Converter/Brake Switch B Circuit Low
    P0720-Output Speed Sensor Circuit Malfunction
    P0721-Output Speed Sensor Range/Performance
    P0722-Output Speed Sensor No Signal
    P0723-Output Speed Sensor Intermittent
    P0724-Torque Converter/Brake Switch B Circuit High
    P0725-Engine Speed input Circuit Malfunction
    P0726-Engine Speed Input Circuit Range/Performance
    P0727-Engine Speed Input Circuit No Signal
    P0728-Engine Speed Input Circuit Intermittent
    P0730-Incorrect Gear Ratio
    P0731-Gear I Incorrect ratio
    P0732-Gear 2 Incorrect ratio
    P0733-Gear 3 Incorrect ratio
    P0734-Gear 4 Incorrect ratio
    P0735-Gear 5 Incorrect ratio
    P0736-Reverse incorrect gear ratio
    P0740-Torque Converter Clutch Circuit Malfunction
    P0741-Torque Converter Clutch Circuit Performance or Stuck Off
    P0742-Torque Converter Clutch Circuit Stock On
    P0743-Torque Converter Clutch Circuit Electrical
    P0744-Torque Converter Clutch Circuit Intermittent
    P0745-Pressure Control Solenoid Malfunction
    P0746-Pressure Control Solenoid Performance or Stuck Off
    P0747-Pressure Control Solenoid Stuck On
    P0748-Pressure Control Solenoid Electrical
    P0749-Pressure Control Solenoid Intermittent
    P0750-Shift Solenoid A Malfunction
    P0751-Shift Solenoid A Performance or Stuck Off
    P0752-Shift Solenoid A Stuck On
    P0753-Shift Solenoid A Electrical
    P0754-Shift Solenoid A Intermittent
    P0755-Shift Solenoid B Malfunction
    P0756-Shift Solenoid B Performance or Stock Off
    P0757-Shift Solenoid B Stuck On
    P0758-Shift Solenoid B Electrical
    P0759-Shift Solenoid B Intermittent
    P0760-Shift Solenoid C Malfunction
    P0761-Shift Solenoid C Performance or Stuck Off
    P0762-Shift Solenoid C Stuck On
    P0763-Shift Solenoid C Electrical
    P0764-Shift Solenoid C Intermittent
    P0765-Shift Solenoid D Malfunction
    P0766-Shift Solenoid D Performance or Stuck Off
    P0767-Shift Solenoid D Stuck On
    P0768-Shift Solenoid D Electrical
    P0769-Shift Solenoid D Intermittent
    P0770-Shift Solenoid E Malfunction
    P0771-Shift Solenoid E Performance or Stuck Off
    P0772-Shift Solenoid E Stuck On
    P0773-Shift Solenoid E Electrical
    P0774-Shift Solenoid E Intermittent
    P0780-Shift Malfunction
    P0781-1-2 Shift Malfunction
    P0782-2-3 Shift Malfunction
    P0783-3-4 Shift Malfunction
    P0784-4-5 Shift Malfunction
    P0785-Shift/Timing Solenoid Malfunction
    P0786-Shift/Timing Solenoid Range/Performance
    P0787-Shift/Timing Solenoid Low
    P0788-Shift/Timing Solenoid High
    P0789-Shift/Timing Solenoid Intermittent
    P0790-Normal/Performance Switch Circuit Malfunction
    P0801-Reverse Inhibit Control Circuit Malfunction
    P0803-1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
    P0804-1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
  8. Pity7700
    awesome. been taking me a while to get to those last ones
