Oil Change Number 2 @1800 miles on new 302
Discussion in 'Engine & Performance' started by nflfreak43, Mar 25, 2013.
  1. nflfreak43
    nflfreak43 Full Access Member
    Smyrna, TN
    Valvoline 5W-30 Synpower... and motorcraft FL-1A filter.
    think it's gonna be a good combo and it's quieted down the roller rockers a lil bit.. not alot... but it did help compared to the Mobil 1 that was in it on the second fill..
    done alot of reading on oils.. especially since i got a job at valvoline Instant Oil change... some good ****.
    bought it all at o'reilly's... 37.24 was my total after tax...
  2. Pity7700
    oil is so damn expensive lol.
    why are you going with a full syn? didnt you just put that engine in the truck?
  3. nflfreak43
    Smyrna, TN
    It has 1800 miles on it.. Going with full sun for the protection and long OCI..
    Sent from my iPhone 4 using Ford Power
  4. Pity7700
    gothcha. if youve got the $$$ go for it!
  5. nflfreak43
    Smyrna, TN
    think about it this way.. 6 qts of conventional and a motorcraft filter runs around 23 bucks.. i spent 14 dollars more, to double the length of my oil changes and get much better protection as a whole...
    come out money ahead..
  6. Pity7700
    good way to look at it.
    full syn doubles you change interval?
  7. nflfreak43
    Smyrna, TN
    typical conventional oil change interval is 3k miles or so.. full synthetic can go 7k and in some cases more..
    check out bobistheoilguy.com and read.. that is the place to learn.. they have tons of members and thousands of used oil analysis on there..
  8. Pity7700
    awesome. good info man. thanks!
  9. jake wells
    jake wells Full Access Member
    park city kentucky
    why not try some syn blend motorcraft 5W30 i run it and it doesn't break down as fast as mobil 1
    i change mine every 5000 miles it cost about 22$ at my small town co-op store
  10. nflfreak43
    Smyrna, TN
    motorcraft 5w30 is hard to find around here and i also only really see it in semi synthetic.. i want full synthetic..
