Previous owner used Motorcraft 5w-20 Full Synthetic..... I was just wondering what others are using. Temps here in Utah avg for 0-100. Last two trucks I had both used Mobil 1 0w-40 Full Synthetic. So the 5w-20 caught me a bit off guard. Looking for thoughts. Thanks Vj
which engine you got? the comp at work actually reccomends 5w-30 for the I6 I know for sure but I think its the same for the v8's
Nope 5w-20 synthetic blend oil is what u should use. I run motorcraft filter and motorcraft 5w-20 synthetic blend
the print on my oil cap has wore off over the past few years but mine had a milky substance on the inside of the cap and my stepdad saidto try thinner oil so I went to 5w-30 on my last oil change so we will see what happens
