Overheating, stumped
Discussion in 'Engine & Performance' started by Nitewolf, Jul 2, 2011.
  1. Nitewolf
    Nitewolf The Big Bad Wolf
    Clarksville, TN
    i spun my fan and it does a full 360 both ways
  2. Nitewolf
    Clarksville, TN
    It will overheat all the time.. at idle and moving
  3. supercrewzn
    its not the fan clutch.. I suspect a water pump or collasping radiator hose
    Check to see if the upper hose is hot and lower is cold.
  4. Nitewolf
    Clarksville, TN
    I only see a upper one..pics?
  5. supercrewzn
    bottom left below the resivor. There is a tee in the hose
  6. Nitewolf
    Clarksville, TN
    ah..ill check later
  7. Nitewolf
    Clarksville, TN
    All hoses are hot thomas
  8. Nitewolf
    Clarksville, TN
    This is at idle
  9. Big'un
    its the fan clutch im tellin u , my rab done it sittin still and movin durin the summer time ...... if the fan spins a 360 then yes the clutch is bad ..... wiggle the fan and see if it moves kinda like a bearing is wore out
  10. Nitewolf
    Clarksville, TN
    CHECKING THE FAN CLUTCH
    A good clutch should offer a certain amount of resistance when spun by hand (engine off, of course!). But if the fan spins with little resistance (more than 1 to 1-1/2 turns), the fan clutch is slipping too much and needs to be replaced.
    If the fan binds, does not turn or offers a lot of resistance, it has seized and also needs to be replaced.
    Fan speed can also be checked with an optical tachometer, by marking one of the fan blades with chalk and using a timing light to observe speed changes, and/or listening for changes in fan noise as engine speed changes.
    You should also try to wiggle the fan blades by hand. If there is any wobble in the fan, there is a bad bearing in the fan clutch, or a worn bearing on the water pump shaft. A bad water pump bearing will usually cause the water pump to leak and/or make noise, but not always. Remove the fan clutch and see if the play is in the water pump shaft. If it feels tight (no play or wobble), replace the fan clutch.
