Overheating, stumped
Discussion in 'Engine & Performance' started by Nitewolf, Jul 2, 2011.
  1. iowaredneck
    mike normal running temp is 180 and 205 degrees for our trucks. i don't think your truck is overheating i think that your temp gauge is reading wrong cause your edge says it's operating under normal temps.
  2. cowboy
    agreed. I switched my edge over to ECT display, when you first mentioned it. I have yet to see my truck get over 200 normally running around 190-196 and my dash gauge is pointing at normal running temp.
  3. 2wd supercrew mudder
    2wd supercrew mudder Full Access Member
    texas
    feel the hose and see if its moving coolant and dont cheap out on efans i did and now i over heat if i run my ac in 104 heat
