p0301 p0430 HELP!
Discussion in 'Engine & Performance' started by Big'un, Dec 30, 2011.
  1. Eric of Memphis
    munford tn
    Hell i told you to take steps.... While doin plugs i woulda checked compression
    Sent from my SGH-T959V using Tapatalk
  2. supercrewzn
    I'm still leaning towards a short in wiring.
  3. supercrewzn
    Compression test would tell you if it's a blown headgasket.
  4. Big'un
    well just put 8 new coils in it , and it didnt phase it .......... FML
  5. LightDuty
    LightDuty Full Access Member
    Michigan
    Time to go get u an 04-08 f150. Jk I know u have house payment n ****. Sux that u can't figure it out
  6. iowaredneck
    really? did you reset everything?
  7. supercrewzn
    Pull both terminals off the battery and then touch them together. This will drain the voltage in the computer and reset it.
  8. ak_cowboy
    How many miles have you put on since replacing them?
  9. Big'un
    probaly 150
  10. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    Did you fix it? If not check the compression. Or do like I did on the 98 and look at the oil cap. By the way it was a head gasket and guess what there wasn't **** on the dip stick I hate ppl that say check the dip stick when I take the cap off and see that it's fuckin blown and look at the cam and see its got milky oil on it.
    Sent from my iFord f150
