P0420
Discussion in 'Engine & Performance' started by DestinationFX4, Jun 13, 2012.
  1. DestinationFX4
    DestinationFX4 Admanistrator
    College Station, TX
    CEL came on this morning, so when i got back to the house i pulled the code - P0420. As far as I can tell its the cat that went bad. Would I be noticing a change in performance or anything? My truck isnt missing as far as I can tell, so I'm wondering what could be causing my cat to go bad.
  2. DestinationFX4
    College Station, TX
    Also, could the code mean that I just need to replace an O2 sensor?
  3. westtnfx4
    I usually pull the light bulb (on your truck you can just cover the Led and be done) because those idiot lights will worry you and nickel and dime you to death.
  4. DestinationFX4
    College Station, TX
    lol i wish i could do that but the fact that its the CEL probably wouldnt be a good idea to cover if something worse happened and i had no idea about it til i was SOL
  5. westtnfx4
    Ok. Go ahead and spend $150 a price on oxygen sensors and buy a new cat for $450 :poker:
    One other thing....I don't need a idiot light to tell me when my truck ain't running right :poker:
  6. Raevsky97
    Raevsky97 bagged 97 f150
    Derby, Kansas
    if its an o2 id just buy a dummy o2 off of a racing site that makes its own code to make the computer run right then your cat problem is also solved i think they sell em on jegs and or summit racing
  7. joh408
    joh408 Full Access Member
    Highlands Ranch, CO
    If you are getting new cats just go with a Magnaflow High Flow cat. Much cheaper than oem
    Sent from my Kindle Fire using Tapatalk 2
  8. DestinationFX4
    College Station, TX
    ok ill look into that. thanks man
  9. DestinationFX4
    College Station, TX
    thats what im going to do if they need to be replaced. ive got a buddy who can get them for 50 each
  10. westtnfx4
    We cut them off here....no testing where me and bigun live :birgits_tiredcoffee
