P0420
Discussion in 'Engine & Performance' started by DestinationFX4, Jun 13, 2012.
  1. Raevsky97
    Raevsky97 bagged 97 f150
    Derby, Kansas
    just cuz its not running bad doesnt mean the cat is not bad it could easily be bad enough to trip the code but not bad enough to cause any driving effects the computer will run the code at certain times at certain temps and if it comes back positive so many times threw the tests it will trip a code it could just be a enough to trip it
  2. DestinationFX4
    DestinationFX4 Admanistrator
    College Station, TX
    ok, well i cleared it so i will wait to see if it comes back and then go from there.
    is there any way to diagnose if my o2 sensor is bad?
  3. Raevsky97
    Derby, Kansas
    yeah if you have a big computer handset a shop has you could look at the voltage readings off of it and see if its jumping from high to slow instead of a steady curve high to low and so on
  4. DestinationFX4
    College Station, TX
    hmm dont got one of those. i might just take it in to a shop and get them to test it
  5. Raevsky97
    Derby, Kansas
    yeah theyll do it it just comes down to how much they will charge u haha
  6. DestinationFX4
    College Station, TX
    yeah thats the part that sucks lol
  7. DestinationFX4
    College Station, TX
    is bank 1 the driver or passenger side?
  8. Raevsky97
    Derby, Kansas
    whichever has cylinder one on it will be bank 1
  9. DestinationFX4
    College Station, TX
    ok thanks man
  10. 06F150
    06F150 Member
    Houston Tx
    bank 1 is your drivers side. the cat can go bad and the truck will run normal, when the cat goes bad, sensor 2 sees the same thing as sensor one and throws a code. put a new cat on and youll be good.
