Painting wheel wells
Discussion in 'General Discussions' started by backwoodscountryman, Apr 5, 2011.
  1. backwoodscountryman
    Backwoods
    Ok so i have been wanting to paint my back wheel wells with a rust proof black paint.
    Should i also scuff up the wells for a better bite?Or just spray right on?Also what grit paper should i use to scuff up?Thanks guys.
  2. VanoFord
    definitely scuff up other wise the first time you get into some mud and fling it up in there, it will act like sandpaper and peel it right off, trust me on that. I would scuff up w/ like a 600-800 grit. dont apply pressure, just let the paper work itself. put atleast 2-3 coats on as I said the first mud hole that flings dirt up in there will act like sandblasting.
  3. backwoodscountryman
    Backwoods
    Thanks man.Ya i thot about a couple coats of paint for the fact i do mud allot.Hopefully it does last.Thanks my Mayhem brother:waytogo:
  4. Nitewolf
    Nitewolf The Big Bad Wolf
    Clarksville, TN
    Yeah I didn't scuff mine at all and hit it with the rustoleum liner. About a month later half was gone and the other half flaking
  5. LightDuty
    LightDuty Full Access Member
    Michigan
    Hey Mike, how's your rockers and stuff holding up with that stuff? Is it flaking off or anything?
  6. Nitewolf
    Clarksville, TN
    Nope.. a tiny pin size chip here and there but went over it again real quick and it went away
