PATS system?
Discussion in 'Engine & Performance' started by MyFX4Project, Oct 24, 2013.
  1. MyFX4Project
    MyFX4Project TRUCKIT
    Kansas
    Well not sure what happened or what did the trick but I unhooked the battery and swapped the fuel pump relay and pcm relay hooked the battery back up and it started.
    No more flashing theft light and its acting normal now.
    Hope this helps anyone who may run into the same problem.
    ....damn ford :jester:
    Glad you figured it all out. I would keep a spare relay in the truck and maybe instructions on what to do if it happens again
  3. iowaredneck
    Probably just unhooking the battery solved the issue but nothing wrong with swapping relays
  4. MyFX4Project
    Kansas
    I know.. it sucks too because I was planning on doing some off roading last night in a badass little field. Instead I ended up going home and fallin asleep.. haha
  5. TxFx04
    Unhooking the battery solves oh so many of my electrical problems lol
    Sent from my iPad using Tapatalk - now Free
  6. iowaredneck
    Bahaha yes it truly does.
  7. 01f1502wd
    x2. That usually fixes my problems too
