Possible engine swap
Discussion in 'Engine & Performance' started by Taylor_allen92, Apr 25, 2013.
  1. Taylor_allen92
    Taylor_allen92 Full Access Member
    Florida
    Well my truck has about 150k on it now and has ran great since ive had it, but now I have a head gasket leak, starter is failing (picking up a new one tomorrow), flywheel has slight dead spot due to starter, slight rod knock (due to the moron who owned it before me), and a couple engine codes I can't figure out for the life of me, I want to start looking into building up my own 4.6 to drop in when it is finished. I really would like more horsepower/torque so I am looking more and more into supercharging it, using a F150 4.6 block, cobra heads, arp studs, and if I can find them I was told to try and use "terminator" pistons and rods, my buddy said that those were the stock pistons and rods from the 02-04 cobras and can withstand the horsepower range I will be looking at. I have been doing quite a bit of research and a few people are saying to use the mustang PCM and wiring harness, any thoughts on this? Also any other advice would be appreciated.
    Thanks
    T.
  2. cowboy
    What's wrong with a 5.4l or find a lightning?
  3. Taylor_allen92
    Florida
    I considered a 5.4, but wouldn't the mpg be worse for the 5.4 both stock and supercharged? I realize that my mpgs will be crap if I supercharge the 4.6, but I am at about 11 mpg city now so I figured it would be even worse with the 5.4. I looked into a lightning swap, but the upfront cost is a little too steep for me. If I build my own I can buy a part here and there over a period of time and throw it on the spare motor.
  4. cowboy
    I'm getting 12mpg with a programmer on my 5.4
  5. TxFx04
    i'm gonna go ahead and beat bama to it.
    *eh ehm*
    COYOTE SWAP
    /discussion
    :jester: nah but sounds like a good, pricey build for sure. do the cobra 4v heads bolt right up?
  6. TFIDDLE
    Coyote!
  7. ak_cowboy
    Just rebuild your current one... Use the Terminator parts and get some new heads if possible
  8. Taylor_allen92
    Florida
    If i can find a cheap enough 5.4 I will look more into it, but I have a buddy who is willing to sell a spare 4.6 block for about $50 with internals, but as far as rebuilding this one, I can spare the down time that it would take to do so.
  9. cowboy
    shoot you can't beat that deal.
  10. TLSF150
    TLSF150 Full Access Member
    Stockbridge, Ga
    Nope.. gotta change crank timing cover intake and alotta **** I dont remember but its easier to just buy a 4v then convert a 2v
