is there anything i can do to get rid of the annoying whine i just changed the fluid in the pump along with the lines and added a filter to it and it is a lot more quiet now, but still annoying.
yes the air was bleed out i will most likely just change out the pump and add some lucas to the mix. i used type F for the fluid because that is all i had on hand but it is better than what it had in it which was burnt metallic smelling chocolate syrup.
