Even in its base form, your latest-generation F-150 is an impressive truck that delivers exceptional capability when used as a workhorse and provides thrills when you’re driving deeper into the desert or challenging off-road terrain. Whatever the task, it requires a reliable set of brake pads that will provide optimum braking power with minimum noise and dust. Engineered to handle the demands of both daily driving and high-performance situations, our all-new Claw Ceramic Front Brake Pads by Baer offer improved stopping power in all weather conditions. They feature a ceramic compound formulated to provide long-lasting, consistent performance and are guaranteed to last a lifetime while offering low rotor wear. Each pad set includes stainless steel abutments and anti-rattle hardware. Baer® - Claw Ceramic Front Brake Pads Specifications: Series Claw; Backing Plate Color Black; Emission Code 6; Grade Type Premium; Slotted Yes; Wear Indicator Attached No; Friction Material Ceramic; Hardware Option Included; Driving Style Daily Driver; Clips Option With Clips; Brake Lube Not Included; Features: Dependable, Consistent Performance with Minimal Noise and Low Dust; Premium High Friction Ceramic Compound; Long pad life with low rotor wear; Delivers a Great Balance Between Maximum Performance and Road-Going Civility; Stainless Steel Abutment and Anti-Rattle Hardware Included with Most Pads; It's a simple upgrade that creates a big impact. Baer Claw Brake Pads are engineered for a precise fit, so they are easy to install, typically following the same process as OEM brake pad replacements.
Enhanced braking performance is just a few clicks away! Upgrade your 2024 Ford F-150 with Baer and ensure it can handle the demands of both daily driving and high-performance situations. Explore more brake system components and learn more about the manufacturer here: https://www.carid.com/baer/
