programer
ranger
Full Access Member
Age
Fond du Lac
what do you guys think of programmers what would be best for my truck?
4.6 5speed on 35s with 3:55 gears for now soon 4:10s or wouldnt it be worth it with a 5 speed i heard they are mainly for the tranny shift points
i just ordered an edge evo so i cant say what it will do for sure but i have heard so many good things about them...this is why i ordered...i know a company out of cincinati that you can get one and a dash pod for your year for just ove 300 bucks....im sure others will pipe up about what they have to say about the edge!
i have a custom tuned gryphon from php for my 5speed and it doesnt do as much as it would if i had an auto but mainly it accounts for my tire size, gear change, and octane change along with some other things it was tuned for.
it shouldnt be a first mod because you can save for the gear swap instead first
does your programmer reprogram your speedo for gear ratio and tire size
no because the 97-98 is done by a gear in the transmission which i already changed out
that's what i thought but i wasn't sure because ik the speed sensor in the transmission is electronically sent to the cluster
where did you change out the gear and where did you get it from?
heres the site. i got the 21 tooth since i have 4.56 and its only 5 over at 70+
its hard to explain but when looking at the trans from the driver side there is a part with cable coming out and held in with one 7-10mm bolt. just unbolt it and pull it out and there will be a gear there held on by a c clip
whats the site you got it from?
yeah ik exactly what your talking about we changed it on my buddy's truck a couple weeks ago because hes speedo stopped working ended up being a loose plug under the dash
