Question about wiring??
Discussion in 'Exterior' started by JLindsay32, Jun 20, 2011.
  1. supercrewzn
    Nope. 55 watts is 55 watts no matter if they are halogen or HID. The amperage draw is what you need to look at. Look that info up.
  2. supercrewzn
    From what I found, the 55 watt halogen bulb pulls about 4.5 amps. I havent found what HIDs pull
  3. jlyoung08
    as a dr i would recommend 0 gauge
    jk 12 should be fine
  4. supercrewzn
    HIDs can pull a max of around 9.2 amps but run about 3.2 amps. So I dont think you would have a problem with the stock wiring. You will have to upgrade the fuse tho.
    That'll bright as hell too. I think you should definitely do the HIDs
  6. JLindsay32
    JLindsay32 Full Access Member
    Humble, TX / Boulder, CO
    Yeah I planned on uprgrading the fuse, and it's not stock wiring, its the wiring harness that came with my 55W lights
