My 2016 f150 5.0l radiator fan has been running on high since I replaced the water pump and thermostat. The first day was normal and then the next day it started running on high speed most. Never runs hot, stays to the left of the middle. Could air be trapped in the system or possible the coolant temp sensor is bad? Worked normal until I changed the pump & thermostat. Thanks for your time.
