rear end
Discussion in '11th Generation F Series : 2004 - 2008' started by muddbug, Aug 8, 2012.
  1. muddbug
    muddbug Junior Member
    Millington
    Ok, im pretty sure its my rear pinion seal leaking. Where is the best place to go to get a new one or can I just buy one from Advance Auto? Im not even sure Im typing this in the right area.
  2. DestinationFX4
    DestinationFX4 Admanistrator
    College Station, TX
    If you want to order online, check out rock auto. If not then just go to advance
  3. J.Wal
    You can get one at any auto parts store. Eric of memphis can hook you up with anything else.
    J.Wal
  4. AKBray907
    your gonna need the dies to install the new seal properly
  5. Big'un
    u can pick one up at the parts house cheap ....... you dont need nuttin but a screwdriver to get the old one out , no puller or nutn ....... and when installing the new one use something a little bigger than the seal so you can tap it in all at the same time
  6. Meatwagon
    Meatwagon Junior Member
    Yorkville, IL
    replaced my pinion seal a few weeks back w/o any issues. Picked it up at Advanced for around $10. Just need to determine if you have the 8.8 or 9.75 differential.
    I used the following write-up and it was a breeze. Only "odd" tool I needed was a gear puller to pull the pinion out.
    You'll loose a bit of rear diff fluid, so maybe pick up a bottle to refill - or even do a complete change while your at it.
    Replace Pinion Seal
    I used a leftover piece of 3" PVC to press the new seal back in the diff.
  7. Tradesman
    Tradesman Full Access Member
    Vancouver, BC
    I personally would go with a factory Ford part, but I generally order from RockAuto since they'e far less expensive than the dealer. I paid the dealer to tackle this for me as I didn't know how to do it myself but now I'm wishing I did it on my own and saved myself a bundle. Remember that if you're topping up your rear diff fluid you may need friction modifier if you have the factory LSD.
  8. AKBray907
    Once again that meat guy dug up a year old post ha
  9. iowaredneck
    Hey its making the site more active
    sent from area 51
  10. Tradesman
    Vancouver, BC
    Yup. I've been a member of this forum for a while now, but one of the reasons why I didn't frequent it was often as I did before is because there was very few posts, very little traffic on the site in general. The other F-150 forum I used to be a member of had over 40+ new threads daily, and that's just on the '04-08 discussion. I'd like to see a lot more members out here considering how laid back this site is, and how everyone is pretty cool (so far). Perhaps we just gotta keep it a small, tight-knit community if brothers rather than have it blow up where we have a couple of brothers and a couple of assholes like what happened at the last place I was at.
    Back to the topic, when I look at the instructions it seems like a pretty straight forward job and that it should not take longer than 1-2 hours to do. Maybe add a bit more if you want to pop off the rear diff cover and do a complete flush of the differential.
