remove the tire take off the hub cap... take the keeper cap off the wheel nut remove carter pin remove wheel nut you may or may not have to remove the rear brakes..depends on whether you have a rear rotor or drum...either way..take the brake line loose if need be... the outer bearing should fall right out take a screwdriver or flat small chisel or punch and knock out the rear seal and race then simply grease and re-assemble bleed your brakes when your dane and thats it...
