Rewiring turn signals
Discussion in 'Exterior' started by ak_cowboy, Oct 3, 2013.
  1. ak_cowboy
    I've got a pair of switchback turn signals that I want to install. However, they are amber with parking lights and flash white with the turn signal...
    Has anyone swapped the wires around? Or have a clue on how to do it?
    [​IMG][​IMG]
    sent from my igloo
  3. Tradesman
    Tradesman Full Access Member
    Vancouver, BC
    Brother, I think you're going to have to go ahead and give it a try on your own. It's weird that the switchback would be amber and flash white, every other time I've seen them they were white and flash amber.
  4. UtahFord
    black is most likely your groundimo dont hold me to that though
  5. TxFx04
    You are a different kind of smart man. Excellent job. Lol JK sometimes brown is ground
    Sent from my iPad using Tapatalk - now Free
  6. UtahFord
    I am your GOD dont forget it
  7. MyFX4Project
    MyFX4Project TRUCKIT
    Kansas
    Not sure why you would want backwards switchbacks lol
    The point of switchbacks is being legal with amber flashers but all white up front with other driving lights. Seems like a difficult task to complete for a not so good result in my opinion. Good luck figuring this one out.
  8. Roush PSD Interceptor
    Left front colors
    Brown is the parking light
    Green/white is turn signal
    Black is ground
    Right front colors
    brown = parking
    white/light blue = turn signal
    black = ground
    Swap the brown and green/white stripe wires
    on the left front and swap the brown and
    white/light blue on the right front.
    Cut them about 2-3 inches back from the factory plug
    so you can "switchback" if ya don't like the result.
    If ya want you can push the terminal release pins inside the
    factory plug and remove the terminal pins and crimped wire
    from the plug and swap them that way. Very tricky to find
    and push the terminal release prongs but it can be done.
    Most people would save the headache of finding and releasing the
    terminal pins so they just cut and swap the wires.
  9. ak_cowboy
    Yeah, I found the pins and all that. Pain in the butt to try and get them to release. I might just do the rewire deal. I don't think it would make a difference with the regular incandescent 3157A bulbs on which filament lights up.
  10. Roush PSD Interceptor
    On the 3157A you would have brighter than normal parking lights
    and the turn signal filament would be a faint blinking
    light output "behind" the brighter bulb filament
    that has become the parking light.
