Rewiring turn signals
Discussion in 'Exterior' started by ak_cowboy, Oct 3, 2013.
  1. ak_cowboy
    Dang, oh well.
    sent from my igloo
  2. Tradesman
    Tradesman Full Access Member
    Vancouver, BC
    Damn brother, that is some great technical information. I wish I knew that earlier, I would have wired up my side marker indicators as turn signals.
  3. Stangshcky12
    PA
    Did you rewire them?
    I got my dad set of 3157 LED bulbs for his brake/turn signals on his ram
    I put them in and thy were being weird, I noticed the prongs/wires at the base of the bulb were opposite of the incandescent bulbs I took out
    I straightened them out and re-folded them back over opposite why they were and they worked fine
    Sounds like it would fix your problem to me
  4. ak_cowboy
    I haven't cut any wires yet. How do you go about switching the wires on the bulbs? Can you just pull off the wire on the base and move it around?
  5. 07Fx2
    07Fx2 Full Access Member
    Oklahoma
    I just wired in resistors on mine :3
  6. AK SNO RIDER
    AK SNO RIDER Got Snow?
    Soldotna, Alaska
    What bulb number are your bulbs? I'm not sure if his method will work since I don't think you have 3157s
  7. ak_cowboy
    I've got 3157s. [​IMG][​IMG]
    sent from my igloo
  8. AK SNO RIDER
    Soldotna, Alaska
    Oh okay, in the first pictures you posted it must have just been what plugs into the base of the bulb socket. Silly me.
  9. AK SNO RIDER
    Soldotna, Alaska
    I see that bulb has 3 prongs coming off of it. You can't spin it 180° and plug it in? Wouldn't that have the same effect as switching the two outside wires on the writing harness?
  10. Stangshcky12
    PA
    Bend these over to opposite sides
