rough country lift
Discussion in 'Lifted' started by ranger, Jan 15, 2011.
  1. Northwoods4x4
    Northwoods4x4 BangBro
    Chula Vista CA
    start diggin :ROFLJest:
  2. Big'un
    a come-a-long & a chain around a tree .... or another ford to pull you out..... post some pics :peace:
  3. yamahasled
    yamahasled Member
    Rosendale WI
    ranger's on the way might have got him odda bed...cranked the torsion keys tonight and got 2.5'' more out of the front end now i got get AAL to raise the back up
  4. ranger
    ranger Full Access Member
    Fond du Lac
    yanked him out no problem then had to go threw where he got stuck had no problem..then we went down the road and messed around in yamahasled's land next to a back road and i got stuck but was still moving just couldnt get over my ruts and he pulled me out then i slid across the road into the ditch sat there for bout 5 min goin bout 10 feet back and forth. needed a little help. then he had to get outa where he was after he pulled me. got stuck in my ruts from the first time i got stuck and went down hill from there blew his rearend.
    yamahasled should have pics wonce he gets his driveshaft out
  5. yamahasled
    yamahasled Member
    Rosendale WI
    well after i got out me and "ranger" started playing around and i ended up braking something internally,not to happy about it either...i dropped the rear drive shaft and put it it 4x4. how long can i run it without a rear drive shaft? I won't have money to fix it for another two weeks hoping it'll limp it around untill then...
  6. swamphunter
    swamphunter Full Access Member
    greeneville tn
    Prolly not very long your axles will prolly start walking out on ya so watch for that if you do have to drive it I've been thru 2 rearends on mine it sucks I got the one that in it now for 100$ came out of a mustang ebay ftw
  7. ranger
    Fond du Lac
    as long as the c clip stays on it should be fine shouldnt it?
  8. swamphunter
    greeneville tn
    Ya but if it broke internal and there chunks of gears in there it will over time eat all the componants in there including you clips mine did this and driving home in front wheel drive the gears went thru the diff cover then it was all down hilll from there axles started walking out
  9. ranger
    Fond du Lac
    that sucks im perdy sure his pinion went,
  10. swamphunter
    greeneville tn
    ya that sucks for sure I wouldn't be driving if it was me he could just pull diff cover and see but pretty sure it won't be pretty
