^^^ dont do that one youll run through ball joints like crazy.
you have to answer a few questions first.
-how long will you run this setup
-how wide of a 33" tires
-stock or aftermarket wheels?
1. this will be on here for the life of the truck
2. no clue
3. stock wheels
if your just going to run stock wheels might do a 1.5 spacer or 2" coils and 285/75/16. the 2.5" spacers need different UCA's to fix the ball joint angles and issues.
you might consider doing 3.5" spindles/small block or aal and 305/70/16 (33x12.50). it will cost a little more than the spacer but if you find some different wheels maybe 8" wide youll love the look.
after having coil spacers on two trucks and having both of them settle between 3/4-1" I wouldn't recommend them.
I'd go for some lift springs. They're more expensive but you'll save money in the long run by not having to buy both like I'm going to have to do.
2" lift coils will level the truck out nicely and might even let you use stock shocks. You can run a 285/75/16 easily and will look nice.
AGjake has it right. Its addicting. You always think you'll be satisfied with a certain amount of lift but you never are after a while.
I have pics of trucks at stock height with 25/75/16, same tire with a coil spacer, and my current truck with a spindle lift,coil spacers, 3" block in the rear and 33x12s
