Mark that actually makes sense lol! And they are goodyear duratracs. Sent from my SCH-I500 using Tapatalk
true, me and rayball aint the smartest catts around but, we kinda figured it out why soft rubber last longer, i was wondering how toyos last so long, and they have way softer tread than dune grapps , or mudd grapps, or bfg mt's, i know this for sure, but your duratracts should be badass, but you better run the right psi, that has alott!!!!! to do with how a tire wears!!
i know it will wear alot better with lower psi, but it will put more of a load on your tranny and motor, cause youll have less rolling resistance, but sicker traction in anything!!, but run the lowest required psi, so the center and the inside and outside of the tire wears equally im sure most on here will tell you that
i run 20-25 in my toyos and i got 50,000 on mine, and still got 35% tread left but you have a different size rim and tire, so it may vary, just look at the psi on the side of your tire, and tell me what the min/max says
