should i pay the dealership?
Discussion in 'General Discussions' started by mustangwarrior, Jul 17, 2011.
  1. 07Fx2
    07Fx2 Full Access Member
    Oklahoma
    Part store ftw
  2. mustangwarrior
    NE Ohio
    t-fiddle, forgot to mention i already replaced the pcv
    and i already had the parts store scan it, and my buddy has the same exact scanner they have at his house
    called a guy i know who is a ford mechanic but does work at his personal garage, he said hes was already swamped with work and kinda blew me off
    now let me ask you guys this, will they be able to tell me whats wrong for sure or am i still gonna be chasing codes?
  3. cowboy
    not sure bud, you maybe still code chasing. I do have a guy in willoughby, oh that is ford certified, does real good work. I know its a haul for ya, but let me know if you want his number. I'll give it too ya.
  4. mustangwarrior
    NE Ohio
    heres the codes we pulled
    P0133 - O2 sensor bank 1
    P0135 - O2 sensor bank 1 sensor 1 heater circuit
    P0141 - O2 sensor bank 1 sensor 2 heater circuit
    P0155 - O2 sensor bank 2 sensor 1 heater circuit
    P1131 - Lack of upstream Heated oxygen sensor switch - lean Bank 1
    P0171 - Bank 1 lean
    P0174 - Bank 2 lean
    P0401 - EGR insufficient flow
    P1409 - EGR vacuum regulator control fault
  5. iowaredneck
    dang that's a huge list
  6. mustangwarrior
    NE Ohio
    yea, the CEL light wasnt on so i was never worried till i started having problems, well turns out the light is either burned out or the bulb was removed when i bought the truck, my mechanic friend just left me message so bout to call him up and see if i can meet up with him
  7. mustangwarrior
    NE Ohio
    so heres what my buddy told me, the first 2 O2 sensors a fried, the sensor for the EGR is fried, the cats are clogged up to the point that they are blowing rubber return lines off of the EGR sensors, (wondered why the one line was always off), and he said the the throttle body is probly gunked up pretty good,
    so basically i've got $150 to replace the sensors and a reason to eliminate the cats and run true duals :jester:
  8. mustangwarrior
    NE Ohio
    and he said that particular motor has a factory hydraulic roller cam :peace:
  9. iowaredneck
    tear them cats out them dood
  10. cowboy
    not sure you can rip out them cats in Ohio... unless you don't have echeck out there. Your in trumbell county right? I know ashtabula doesn't have echeck. I need to find out if my county has it.
