Show Off Your Lights!
Discussion in 'Exterior' started by ak_cowboy, May 6, 2011.
  1. ak_cowboy
    Well shoot...now I got something else to do... You're truck has the sickest LED setup I've ever seen
    How did you wire the Show-Me in? The directions online look like its only setup to run 2 leds.
  2. Platinum_Sean
    Platinum_Sean Junior Member
    Canada
    The Sho-me has 2 outputs. What I did was take these 2 wires, and put them on one side of 2, 2-pole, single throw switches. Each switch then controls what set of lights you want on, when the flasher is on. I put 1 switch for the fronts, 1 for the rears. On the output of the switch, I run lines to any number of LED lights I want.
    For the cargo, signal, and reverse lights, I broke open the OEM wire to each light, added a diode. I added another diode, cathose pointing to the light, anode to the wire from the switch mentioned above. This way, the lights work as they do normally, and do not reverse energize other lights on the same circuit. As well, with the LED flasher sending juice to the light, the other diode prevents reverse engerzing as well.
    For the cab lights, 1 used a 2-pole, 2 throw switch. 1 side is the running lights, bridged across both leads, middle are the 2 circuits for the cab lights (outter 2 and middle are 1 circuit, other 2 are the other), and the other leads of the switch go to the front LED flasher switch. This way I can toggle the cab lights to work with the LED flasher, or, with the truck's running lights.
    I put things on paper with pencil if you really want to see this, its more thinking and running wires, soldering diodes, then anything.
  3. Ak 08 stx
    Ak 08 stx The Only One
    North Pole, ALASKA
    according to my dad, he says that **** is illegal up here, but i dont beleive him
  4. ak_cowboy
    Only if its red and/or blue. Amber flashers can't be illegal, cuz then you wouldn't be able to use your hazards.
    Not to say red/blue can't be used "off-road only" :shooter:
  5. DarkShadowSTX
    DarkShadowSTX the "brat"
    Brecksville, OH
    5k hid retrofits in the heads from retrosolutions
    2 hella 500 driving lights behind the grill
    2 hella 500ff driving
    2 hella 500ff fog
    v-leds switchback turn signals
    YouTube - ‪F150 5k switchback led turn signals‬‏
    recon xtreme led tailgate lightbar
    vleds 92 led taillight bulbs, led bulb on right compared to stock bulb on left
    red v-leds dome and map bulbs
    also have blue
  6. DarkShadowSTX
    Brecksville, OH
    led backlighting behind my hid projectors
  7. Roush PSD Interceptor
    That is an awesome LED light setup Sean.:peace:
    Now I have to put all 4 of my SHO-ME boxes on one truck.:jester:
    I have two HD 6amp units and two standard amperage.
    Double diode isolation a one way valve for electrical currents.
    Looks like you have a different flash pattern on yours,
    the ones I have were bought about 10 years ago.
  8. Roush PSD Interceptor
    Lee
    Do you know if those projector backlighting LEDs change colors within the LED
    or are there seperated sets of LED for each color?
  9. DarkShadowSTX
    Brecksville, OH
    these are the led rings that are behind the projectors. it looks like the leds themselves change color
  10. cowboy
    nice lights guys
