sluggish start
Discussion in 'Engine & Performance' started by mustangwarrior, May 31, 2011.
  1. mustangwarrior
    NE Ohio
    yea but i need a vacuum guage, which i dont have nor do my buddies, so im gonna try to get a hold of one soon
  2. TLSF150
    TLSF150 Full Access Member
    Stockbridge, Ga
    Hmm I'm not sure but some auto stores like autozone rent tools.. one of em might let you rent one...
    Sent from my iPhone killing HTC Inspire 4G
  3. mustangwarrior
    NE Ohio
    well just replaced the FPR and it didnt fix it, and now it bucks and kicks around 45 mph doesnt even wanna cruise anymore
    did some research on the FPR and really thought that was it, it described everything wrong with it, now im really upset
    so now i guess i need to get a fuel pressure gauge and if the pressure is too low then possibly the fuel pump? and if its good then a bad injector?
  4. TLSF150
    Stockbridge, Ga
    Yeah sounds like a plan.. id definitely check your pressure before throwing money at it again though
  5. mustangwarrior
    NE Ohio
    well just measured the fuel pressure at the fuel rail
    it should be:
    35-45 psi - key on, engine off
    30-45 psi - key on, engine on
    it read:
    25 psi - key on, engine off
    28 psi - key on, engine on
    in both tanks,
    so as long as i did it properly, that would lead to the fuel pump, but both tanks are the same, and the fuel filter is brand new so thats not the issue
  6. The Batman
    The Batman Rest In Piece
    cold hill ky
    injectors or bad or clogged line....r u sure you did the pumps right?
  7. iowaredneck
    there's a fuel pump on the rail of the truck outside of the tanks, that might be the problem
  8. mustangwarrior
    NE Ohio
    all i did was connect a pressure gauge to the schrader valve on the fuel rail
  9. mustangwarrior
    NE Ohio
    also it seems to be running better since i replaced the FPR, drove it for the first time in a week today, it seems to idle a little smoother and just has a slight stutter now, and sometimes after brief stops it doesn't do it at all, idk if its due to the cooler weather? the other day i drove it before i replaced the FPR, it was 90 and i had the air on and it stuttered real bad almost stalled and bucked like crazy when cruising
  10. The Batman
    cold hill ky
    glad its better dood......:peace:
