So Confused!!!!! Need help
Discussion in 'General Discussions' started by Bad Company98, Nov 27, 2011.
  1. Bad Company98
    Bad Company98 Full Access Member
    Eastren Shore MD
    I have been having weird noises from my after market intake I have had it on for 6 months and just randomly it started vibrating and making a humming noise! Cant figure it out I replaced my ICA and made brackets to try and suport it better. It still does it. And just recently my heating will stop flowing threw the vents when I get up to around 55 going down the road for a little ways than when I let off the gas It starts flowing again I believe its a vaccum leak? What do you guys think????
  2. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    Is it a vibrating noise or a whine? What intake is it?
    Sent from my bad ass phone
  3. supercrewzn
    The heat issue is a vacuum problem
  4. iowaredneck
    Did you take your silencer out when u installed the intake?
  5. Screamin.03HD
    Lexington, TN
    vacuum leak. with it running spray carb cleaner around all vac lines and gaskets, when the engine stumbles, u found your leak. u should also have P0171 and P0174 lean codes
  6. Raevsky97
    Raevsky97 bagged 97 f150
    Derby, Kansas
    what this guy said...best way to solve this problem
  7. Bad Company98
    Eastren Shore MD
    I sprayed the line with carb cleaner and couldnt find anything Im getting my friend to hook a smoke machine up to my truck to see if I can find it what do you mean by lean codes?
  8. Bad Company98
    Eastren Shore MD
    It hasent thrown any codes and I ran a dignastics test on it and everything seemed to check out.
  9. Bad Company98
    Eastren Shore MD
    And its a volant cold air intake
