spindle lift/ bushings
Discussion in 'General Discussions' started by 2wd supercrew mudder, Sep 11, 2011.
  1. 2wd supercrew mudder
    2wd supercrew mudder Full Access Member
    texas
    so finally ordered the 3.5 spindles lift :peace: . but i got a horrible squawk coming from the rear i think its my leaf spring bushing has any body replaced the bushings
    2003 f150 super crew 2wd 170,000
  2. Pity7700
    most likey the small pads inbetween the leafs is your "squwak". at the end of each leaf there is a little plastic piece taht goes in between that leaf and the one above. just get some rubber or some thing and pry the leafs apart and stick it in there, should fix it. congrats on the spindle lift. post pics!
  3. 2wd supercrew mudder
    texas
    thanks i will when i install it. but it sounds like its coming from the bushing to me
  4. Pity7700
    Check it out. There's a lot more with changing the bushing.
  5. BlackThundah
    Maybe try some greece??
  6. 2wd supercrew mudder
    texas
    ill try both and see what happens
  7. 97madness
  8. 2wd supercrew mudder
    texas
    :rotflmao:
  9. 2wd supercrew mudder
    texas
    so i found the problem its a body mount not the leaf springs its the right rear in front of the tire guess ill be replacing it soon
  10. BlackThundah
    :flipthebird:
