Start up
Discussion in 'General Discussions' started by Sl33p3r, Feb 14, 2012.
  1. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    Ok for 2 days the 1st start up of the day the truck won't start if I leave the key on for a little while then try the 2nd time it will start. Any idea what is causing this?
    Sent from my iFord f150
  2. iowaredneck
    fuel pump
  3. Darth Bama
    Could be several things. fuel pump, ignition switch about take a shat.
    Do you hear the fuel pump priming once you roll the key over?
  4. ak_cowboy
    I'd check fuel pump. When did you last change your filter also?
  5. Big'un
    fewerl pump dawg
  6. supercrewzn
    Pump only has to prime about 5 seconds. If your waiting longer than that, id guess something other than pump.
  7. cowboy
    battery?
  8. Darth Bama
    Canooter valve? Possibly a muffler bearing going bad? :hmm:
  9. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    It started fine today. I left the key on till it stopped dinging. If its the pump I would have driving problems wouldn't i?
  10. iowaredneck
    you will eventually, the prime in the pump is getting weak and not giving you enough fuel to start
