its the stock battery and starter so probably one of them is going out i just don't want to get stranded haha
You can test it yourself by jumping it from another car. if it fires right up id start athe battery, if it still clicks than its probably the starter.
ill just go out and test it with my volt meter where do you put the leads to test the starter and thanks guys for the advice
I wouldnt say starter.. the solenoid is the link between the two.. it has to engage before the starter will..
Easy way to test your battery is to turn on your headlights. If you try to crank it with the headlights on and a dead battery your lights will go out or really dim. otherwise I would say terminals.
