Steering Stabilizer Question
Discussion in 'General Truck Discussion for all Generations' started by Tradesman, Sep 10, 2013.
  1. Tradesman
    Tradesman Full Access Member
    Vancouver, BC
    I see many trucks with steering stabilizers, more specifically on one tonne trucks or trucks with very high lifts on them. Would it be worth it to install a steering stabilizer on a bone stock truck? I came across an add on eBay for a steering stabilizer kit from Fabtech that would fit my truck. Not that there is anything wrong with the steering on my truck, I just wanted to see if there's any advantage if the truck hasn't been modified at all.
    Installed one on my 2000 F250 4x4.
    There were factory Ford brackets and a dimple in the drag link
    to attach the stabilizer brackets but it didn't come with one
    from Ford.
    Made a big difference in the steering feel especially on bumpy
    and pothole filled roads. No sudden jerk from a roadway defect
    to tire then to steering components and then to steering wheel.
    Took a few days to get used to the steering
    feel with the new "dampener" attached to the drag link.
    Made the steering feel better in the long run
    I can't imagine taking it back off and driving without it.
  3. 01f1502wd
  4. 97madness
    Our roads here are really bumpy. I found myself gently holding the steering wheel on most roads as it jerked so bad. Mine has helped, feels much smoother and everything.
  5. TxFx04
    I heard something about steering stabilizers putting an unneeded load on your tierods and even causing them to snap. :shrug:
  6. 97madness
    Understandable. It's an added resistance if you're not smashing potholes/rough roads or off roading where you would need it to help.
  7. TxFx04
    A few guys on f150online have snapped tierods clean off
  8. 97madness
    I thought that was due to the dual stabilizers?
  9. Pity7700
    i love my steering stabilizer. not going to lie.
    saw a difference when I installed it compared to not having one with my 35s. I feel it was a good purchase.
  10. 4ctNduction
    T-E-X-A-S
    on new fords (mostly f250s+) we reccomend them if the truck is lifted. the new fords for some reason jerk the steering wheel if you hit a bump
