Strange, bad, shaking
Discussion in 'General Discussions' started by AK SNO RIDER, Jun 16, 2011.
  1. AK SNO RIDER
    AK SNO RIDER Got Snow?
    Soldotna, Alaska
    As I accelerate my entire truck shakes. Usually once I hit 30-40mph it goes away, but each day it's getting worse. It will also shake around 20-25mph steady speed. It's getting to the point where I can hardly drive the truck. Any ideas? My dad said to check u-joints, I did and they are fine.
  2. The Batman
    The Batman Rest In Piece
    cold hill ky
    are you sure about that? sounds like u-joints or ball joints...could be wheel bearings too...jack the truck up and shake down the front tires...do you notice a clicking or clanging sound?...a vid would be helpfull
  3. AK SNO RIDER
    Soldotna, Alaska
    I also noticed my transfer case seems to have a little play, when I push up and down on the rear of it it will move some. Doesn't feel loose, just moves. I can get a video up of both problems later tonight.
    The ball joints, upper control arms, front shocks and a few other things were all replaced just recently.
  4. The Batman
    cold hill ky
    sounds like a briken tranny mount...but a vid will help narrow it down...
  5. AK SNO RIDER
    Soldotna, Alaska
    The T-case vid is uploading right now, when it's done I will take one of the shaking and upload it.
  6. The Batman
    cold hill ky
    good
  7. AK SNO RIDER
    Soldotna, Alaska
    My phone decided it didn't want to finish the upload, so I'm doing it through my laptop. Sorry for the wait.
  8. The Batman
    cold hill ky
    take your time
  9. ak_cowboy
    Check all your lug nuts
    Jack each wheel up and check for play around the hubs
    Have you ran over anything recently? A damaged driveshaft would really wobble
    Also check the driveshaft bolts, the ones that hold it up.
    If still nothing, spend $100 for an hour of shop time at Ellis and have them look at it. They are really great guys that'll hook you up.
  10. The Batman
    cold hill ky
    you can allways give me a call while your under the truck and i can talk you through every thing..one thing at a time
