subs not playing
Discussion in 'Audio & Electronics' started by mustangwarrior, Oct 6, 2012.
  1. mustangwarrior
    NE Ohio
    so i got a small kenwood amp hooked up to a 10" MTX in my jeep, been working fine, plays nice and clean, well it quit working
    the amp is getting power, it lights up and all that, but is not sending power the sub, we checked all connections, hooked a speaker up to it to test it and nothing, no meter readings off the terminals
    any thoughts?
    If you're getting signal from the RCA's to the amp
    and everything lights up, the speaker isn't blown and
    the speaker wires have good continuity it may
    have went belly up.
  3. AK SNO RIDER
    AK SNO RIDER Got Snow?
    Soldotna, Alaska
    Any chance you have a friend with the same brand deck? You could do a plug and play swap to see if its your deck.
    My friend had a problem real similar to this. Amp was powered up, subs were good. Ended up the deck had gone bad. Everything on it worked aside from not sending signal to the amp.
  4. mustangwarrior
    NE Ohio
    i'm gonna have to check the rca's next to make sure its getting a signal
  5. W.Hirsch
    W.Hirsch Yippie-Ki-Yay....
    Millington, TN
    Kinda stupid but check and make sure you didn't accidentally turn off the sub through the head unit.
  6. mustangwarrior
    NE Ohio
    yea i got that covered haha, main power feeds are all good, amp comes on but no signal to the sub, we tried a speaker and it didn't work either
  7. Big'un
    sounds like u got a fried amp
  8. UtahFord
    Fried amp dood
    sent from my F-350
  9. W.Hirsch
    Millington, TN
    Yep like they said. Time for a new amp
