Subwoofer Issue
Discussion in 'Audio & Electronics' started by Bdons-SD, Jun 21, 2011.
  1. TFIDDLE
    Mine actually did that yesterday because of the heat
    Most 2 channel amps are bridged using this configuration,
    the speaker side pictured is a single voice coil setup:
  3. TFIDDLE
    2channels are a/b and more prone to heating arent they?
  4. supercrewzn
    My suggestion was that you had the sub wired wrong. My subs have never cut out because of overheating issues or any other issue for that matter.
  5. Bdons-SD
    I'll get the specs for everything and my exact wiring diagram and maybe some of y'all with more experience can doube check my work.
    I suggest the same for jarrett.
  6. 01f1502wd
    well tyler, you know my set up.... i have my amp underneath my pass. backseat. i guess it could be overheating...
  7. TFIDDLE
    My overheated yesterday. Class ab amps run a bit hotter expecially wen it was over 100 inside my truck
  8. supercrewzn
    My amp is in the storage compartment behind the back seat. I have a class D amp with no cooling fan. Im not saying it isnt possible to overheat because of it being hot.
  9. TFIDDLE
    mine is behind seat also with 2 cooling fans but my truck had been setting in open sun then i was hitting pretty hard before they went out
  10. Bdons-SD
    this is a rough drawing of how its wired. the pos and neg on the sub are jumped to the other pos and neg terminals. Maybe someone can tell me where I went wrong. also heres a list of the models of my equipment. thanks for all the help guys!
    my amp is the mrp m350
    my hu is a pioneer deh p3900mp
    my sub is the alpine type s 12 inch 2 ohm dual voice coil
