Supercrew tow mirrors HERE!!
Discussion in 'Exterior' started by 01f1502wd, Feb 18, 2011.
  1. 01f1502wd
    ^damn. that paint store is literly just down the street from me. ill check it out.
    what kind of power sander would you recomend for all projects?
  2. agjake11
    agjake11 Suck my tailpipe
    Rosenberg/Baytown TX
    you can probably get by with a cheap orbital since the surface your sanding is open more than my console or the multi tool oscillating i have
    then you could also get a dremel for smaller areas
  3. 01f1502wd
    what kind is your multi-tool one?
  4. agjake11
  5. 01f1502wd
    well...my roommate said he didnt care wether i did my truck stuff in the common room...but ive got an entire lift kit, 35" tires and wheels will be here monday....and now this...surely he will hate me lol
    so the resin is like glue? so ill just use that to hold the two pieces together?
  6. agjake11
    kinda but DO NOT do it inside. it smells and your roomates will HATE you
  7. 01f1502wd
    ah ok. i know theres some plugs outside my building i could use. well im goin to bed so anything else yall wanna add ill get to it tomorrow morning. and ill pick up that sander after work.
  8. agjake11
    do not mix or lay resin inside and then when you sand wear long pants and sleeves and a mask because it will get messy and itch fast. do both outside and might want an air compressor near by to blow the dust off the parts and you
  9. 01f1502wd
    hmmm...i have no air compressor... hair dryer should do the trick lol
  10. c418
    c418 Full Access Member
    :big_banana_Dance:
