Suspension Issues, lift questions...
Discussion in 'Lifted' started by .ScRuMpTiOuS., Apr 16, 2011.
  1. rrogers
    the u bolts should run about 5 dollars a piece
  2. TxFx04
    yes ^ and that comes with tie rods too, might as well replace it all
  3. .ScRuMpTiOuS.
    .ScRuMpTiOuS. Full Access Member
    Houston, TX
    oh yea, thats way too much! maybe i can pay you some labor with a case of beer! lol
  4. .ScRuMpTiOuS.
    Houston, TX
    man good thing u guys told me, i may just buy this stuff and do it myself! instead of getting ripped off...
  5. rrogers
  6. TxFx04
    ha hey i would do it for some money, i did it all pretty much by myself on my truck and it took about 3 hours so it should be easy
  7. Pity7700
    if the shop went ahead with the alignment the parts listed shoudl still be ok unless they're retarded and went ahead and did the alignment anyways. I wouldnt pay them to do all that work i mean **** to replace that upper balljoint/control arm (comes as one piece) it would only cost you lik $45 for a Moog balljoint/control arm from amazon. you can do all that work yourself and save a ton of money. Those prices are sky high man. you can get the parts for probably less than half of what its going to cost you to have all that done by them. My question is how bad are all the balljoints. you could test them yourself but you'd need a dial indicator. i believe they should have a maximum play of .035" to .050". if the boot is ripped it'll need to be replaced either way.
    I would get a second opinion or go ahead and do it yourself. Again the parts cant be that worn out if they did the alignment, unless they just tried to trap you into spending a ton of money.:flipthebird:
  8. TFIDDLE
    I paid 20 bucks for my lower ball joints and idk how much an upper is
  9. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    buy the parts and do it yourself. It cost me $200 do do mine
  10. .ScRuMpTiOuS.
    Houston, TX
    i think i'll do that thanks guys.
