supercrewzn
Full Access Member
I swapped all my interior dome lights to leds. This applies to my screw so there is a couple that some of you will not have.
First start off my removing the cover for the dome light. It just pops off. You will see the slot. Then remove the 3 screws and unplug it.
Now the map lights have a metal cover that needs to be removed to access the bulb.
It also just pops off.
Here is the bulb and metal cover removed.
Here is the led installed. Make sure after you put the bulb in, plug it back up and check that it works. If it doesn't, then flip the bulb around.
You will also want to aim the bulb. Put the metal cover back on as it helps reflect the light towards you.
Here is what I used for the center dome light
It is 2 led boards. I had to modify the dome light to get them to fit. A dremel works best. I cut a small section on each side to get the board to fit.
Here is a pic of the board with the cover installed
Here is the map lights with the leds. Excuse the peeling paint. I gotta take care of that.
Center and maps
Night shots
Next is the rear map lights.
To swap these, the entire map light will pop down out of the headliner.
Next pop the main cover off and swap the bulb. Make sure it works. Then put it back together and back in the headliner. These pics seem to be missing.
Old
New
Center and maps
Night shots
Old
New
