the new guy
Discussion in 'Lifted' started by grizzlyf150, Feb 7, 2012.
  1. grizzlyf150
    grizzlyf150 Junior Member
    parkton, nc
    What's up to everyone who is reading this, i just registered on. I know most of you have answered questions about lifts over and over so please help me out. I have a red F150 sidestep fx4 with the 5.4 v8 triton with the matching removeable cargo top. I go mudding quite often and the truck is completely stock at this point. I looked at a few trucks on this forum and wandering what are the pro's and con's in lifting the truck, also would it be a good idea to get a 3 inch body lift with a 3 inch suspension lift, and 35 inch tires?
  2. Big'un
    Welcome bub!
    what year is your truck?
  3. jlyoung08
    welcome!
  4. 01f1502wd
    Wazzzzuupp doood
    And boom goes the dynamite.
    :welcome: pics!
  6. Big'un
    Ill go ahead and post .....
    97-03 F150 - stay away from the 3" suspension kit/torsion keys they wear ball joints and make your cv angles bad ...... 3" body lifts are well worth it , ive had them on all the 97-03 i have
    04-08 F150 - some say the 3" leveling kits are bad and put your joints at bad angles and some say there fine .... and a 3" body lift is worth it on these also , my bro has one on his 04 f150
    and with a 3" body lift on either of these trucks u can 35s easily , on 04-08s you can run 35s with just a 2.5" leveling kit , on 97-03s you can crank your torsion bars and run 33s
    Hope i helped
  7. jlyoung08
    youre perfectly right^^
  8. DestinationFX4
    DestinationFX4 Admanistrator
    College Station, TX
    Yeah, definitely stay away from a 3in leveling kit if you have a 2004-2008. You might luck out and not have any problems, but its better to be safe than sorry when you can easily run a 35" tire with a 2 or 2.5in leveling kit.
    Also, if you arent going to do the labor yourself, you might want to stay away from getting a body lift. Usually shops are outrageous on their labor quotes for installing one, and when it is all said and done, it will only cost an extra couple hundred for a full 6in suspension lift.
    and welcome to FFS!
  9. Big'un
    Might i add body lifts are a easy install if you have regular hand tools and common sense
  10. TFIDDLE
    I have 6inch suspension lift and love it but just for mudding and stuff, get a 3inch performance accessories body lift
