Best turbo for 4.6, all different brands, and good enough for stock bottom end and good enough for forged bottom end. Sent from my SCH-I500 using Tapatalk
i only recommend turbobygarrett. any other brands you'll have to do a comparison to the Garrets to make sure they are the same specs. for your 4.6, i recommend either the GT3788R or the GT4088R. You would want to use a smaller A/R for the 4088 to reduce the amount of lag (not that there will be a lot) since you are running a turbo that can handle up to 6.0L.
When I was in screen printing I did a bunch of shirts and jackets for them. I accually have some that I wear. Wonder if I can get a discount lol
a turbo and its workings are all relative, regardless of fuel. the biggest problems w/ upsizing diesel turbo's is the fuel. its not like you can just increase the injectors like we have. you need a whole new pump to push the new flow needed, and pumps are expensive.
U can put a different compressor wheel In to boost the psi a lil bit. We did that so much when I used to work at turbo power systems
