Ticking sound
Discussion in 'Engine & Performance' started by TxFx04, Sep 25, 2011.
  1. TxFx04
    when my truck is idling, on the inside i've noticed a slight ticking.it's not too loud like it would be something internal but it is noticeable. i was wondering what the infamous cam phaser going out sounds like or any other common problems with the 04 that i might have(already had window motor go out :Grenade:) i'm not throwing any codes and ive scanned with the edge and still nothing. if the cam phaser goes out will it throw a code?
  2. supercrewzn
    More than likely it's a cam phaser. It could be a noisy fuel injecting also. Mine are loud on my truck.
  3. TxFx04
    its cause my truck has no drone when it idles so i can pick it out
  4. 07Fx2
    07Fx2 Full Access Member
    Oklahoma
    5.4, with a slight ticking is fuel injectors or a exhaust leak. If you had the famous cam phaser noise it would be soundling like a diesel.
  5. TxFx04
    it could be exhaust leak. on a cold start it has the hissing like an exhaust leak but it goes away to nothing
  6. westtnfx4
  7. TxFx04
    "If you have a VCT knock this will generally be present when the oil has reached operating temps of over 160 degrees" the oil is usually over 160 after a good warm up and driving around a little then say i stop a a stop light i'll hear it.
  8. westtnfx4
    Does the tick go away ABOVE 1,000-1,200 RPM's? If it ticks all the way threw ALL RPM's it's cam phasers. If it goes away after 1200 RPM's it's the VCT sensors.
  9. The Batman
    The Batman Rest In Piece
    cold hill ky
    lifter......
  10. westtnfx4
    We are talking 3v 5.4's here bats gtfo :jester:
