tongue weight capacity
Discussion in 'Tech Info' started by allen796, Jan 25, 2013.
  1. allen796
    allen796 Junior Member
    Prairieville, La
    I'm looking at purchasing a travel trailer with a shipping weight of @5800# and questioning any concern on hitch (tongue) weight? Is there a listed maximum capacity for tongue weight on my vehicle?
    My vehicle is a 2010 F150 XLT with towing package. 4.6l 3V engine, 3.31 rear end. What concerns should I have?
    Ernest
  2. VanoFord
    it should be listed directly on your hitch what its limits are. I'm assuming you have atleast a C3, but maybe a C4 hitch. That will make the difference in what your tongue weight can be. I would crawl under and take a look, should be a tag on the hitch. the 5800# might be just a bit too much w/ the C3, but should be alright w/ the C4, and should be fine in either case if you use a Weight Distribution system as well, since they essentially double your capacity.
    also, make sure that you stay w/in your trucks GVCW when accounting for a full tank of gas, trailer, bed full of cargo, and all your passengers.
  3. ak_cowboy
    With the 4.6 V8 and 3.31 gears you're only limited to towing 8000lbs. Tongue weight should be around 10-15% of total weight.
    http://www.ford.com/assets/pdf/towing/10FLMrvF150sep09.pdf
