Gotta sand and prime then ready for paint Some more spotting putty and then sand and prime then paint time
The transmission is making a noise but its different now. It's a loud pop noise on acceleration from a dead stop. The output shaft also has some play that doesn't seem normal. Here's a video http://youtu.be/PbM0Zb-ussw
The rear of the transmission has always had a coat of oil on it since I know. It doesn't look like its leaking more.
Like check your dip stick an see how it looks, it's should be Ruby red, not brown or Metallicy or anything
Ill check it tonight. I am scheduling a appointment at quality again because its free if it happens with in a month
The output shaft on the 4r70w uses the driveshaft input as the bearing.. It sounds like the output seal is bad causing the leak an the clanking. Not to bad or expensive for them to replace if I'm correct.. Smokin' Tires with my 5.0 on Tapatalk
No.. They litterally just pull the driveshaft and the seal is right there where the driveshaft comes from the trans.. But this is PURELY MY GUESS.. It may be this, it may not be.. This is my best educated guess.. Smokin' Tires with my 5.0 on Tapatalk
