Transmission Woes
Discussion in 'General Discussions' started by ak_cowboy, Feb 5, 2011.
  1. Nitewolf
    Nitewolf The Big Bad Wolf
    Clarksville, TN
    Is your truck the 2004 in your details or the 2007 in your sig? and is it heritage or anything like that? and 4wd or 2wd?
    It's a 2007 4wd, 5.4 v8, 4R75E auto trans. A how to would be.great!
  3. Nitewolf
    Clarksville, TN
    on its way :D
  4. Nitewolf
    Clarksville, TN
    Says the tranny your supposed to have is the A340F?
    That's a Toyota trans.... mine is 4R75E
  6. Nitewolf
    Clarksville, TN
    Damn, Chilton is totally F'd up then.. it says A340E and A340F for all the years
  7. Nitewolf
    Clarksville, TN
    Automatic Transmission Assembly
    Removal & Installation
    To Remove:
    Before servicing the vehicle, refer to the precautions at the beginning of this section.
    Place vehicle in neutral.
    Safely raise and support the vehicle.
    Remove or disconnect the following:
    Negative battery cable
    Transfer case (4WD Vehicles)
    Transmission fluid pan (if transmission is to be disassembled)
    Drain fluid and reinstall pan
    Driveshaft flange marks
    Mark the driveshaft flange and rear axle pinion flange (2WD Vehicles).
    Bolts and rear driveshaft (2WD Vehicles)
    Fuel line bracket from extension bolt (2WD Vehicles)
    Shift cable bracket
    Flexplate inspection cover
    Rubber access plug
    Flexplate-to-torque converter nuts
    Discard the nuts
    Starter motor electrical connector cap
    Electrical connectors
    Starter motor
    Transmission cooler lines and position aside
    Bolt for the transmission filler tube on RH cylinder head
    Position tube aside
    Bolts for exhaust hanger
    RH exhaust shield bolt
    LH exhaust shield bolt Place and secure a transmission jack under transmission. Remove or disconnect the following:
    Rear crossmember bolts
    Rear transmission retainer nuts
    Crossmember
    Rear transmission support
    Transmission electrical connectors
    Transmission range sensor electrical connectors
    Output shaft speed sensor electrical connectors
    Solenoid body assembly electrical connector Position a drain pan;
    Insert plug into transmission (if fluid was not previously drained) Remove transmission-to-engine bolts;
    Note the lengths and locations of all bolts
    WARNING
    Secure torque converter in transmission. Injury can result if it falls out of the transmission.
    Special Tool installation
    Install special tool after sliding the transmission back horizontally to provide access.
    Lower the transmission nose-down to clear the flexplate and exhaust.
    Disconnect vent tube (4WD Vehicles).
    To Install:
    Ensure that the special tool is installed.
    Position vent tube on top of transmission (4WD Vehicles)
    Place and secure transmission on transmission jack.
    Transmission installation with the jack
    Raise and position transmission into the vehicle allowing the shaft tail to go over the exhaust, and piloting converter housing into position by dowels in rear of the engine block.
    Place transmission in horizontal position and remove the special tool.
    Move the transmission toward the engine aligning the orange balancing marks between the torque converter studs and flexplate bolt holes.
    Install or connect the following:
    LH Transmission retaining bolts in correct locations
    (as noted during removal)
    Torque to: 35 ft. lbs. (48 Nm)
    RH Transmission retaining bolts in correct locations
    Solenoid body connector
    Connect harness retainer to transmission
    TR sensor connectors
    Torque to: 59 ft. lbs. (80 Nm)
    Rear crossmember into place
    Rear transmission support nuts
    Torque to: 76 ft. lbs. (103 Nm)
    Torque to: 66 ft. lbs. (90 nm)
    Remove the transmission jack.
    Torque to: 11 ft. lbs. (15 Nm)
    Bolts connecting exhaust hanger to crossmember
    Torque to: 30 ft. lbs. (40 Nm)
    Transmission fluid fill tube onto RH cylinder head with the bolt
    Torque to: 9 ft. lbs. (12 Nm)
    Transmission fluid cooler tubes
    Torque to: 15 ft. lbs. (20 Nm)
    Starter motor and bolts
    Starter motor electrical connector and ground wire
    Torque converter nuts;
    (Rotate the crankshaft to access all nuts)
    Torque to: 27 ft. lbs. (36 Nm)
    Rubber access plug
    Torque to: 25 ft. lbs. (34 Nm)
    Shift cable end and bracket
    Fuel line bracket (2WD Vehicles)
    Torque to: 18 ft. lbs. (25 Nm)
    Driveshaft to transmission;
    Aligning yellow dots (2WD Vehicles)
    Driveshaft to rear differential;
    Aligning marks, and the bolts (2WD Vehicles)
    New inline transmission fluid filter (or kit if vehicle was not equipped)
    Unless no internal repair was performed
    Lower the vehicle.
    Fill transmission fluid.
  8. yz85rider2002
    thats good stuff right there
  9. ak_cowboy
    That's some sweet info. What's the special tool they talk about in the middle? The one reason I'm hesitant about installing it myself is if I forget one step and toast another tranny... I know Ford will do it right and give me a 1 year warranty on their work.
    Here's how today went. Found a tranny 3 hrs away for $900 (with $100 core), 1 and 2 year warranties are available. Trans shop can install a shift kit for towing for $325 total, a performance (race) kit would be around $600. And finally, Ford charges $650 to install the transmission with a 1 year warranty on whatever they do.
    That comes to $1875...
    Mag-Hytec Pan is ~$260. They only list one for the 4R70, I'm pretty sure that it'll fit mine too.
    Digital Trans Temp Gauge from Summit. $60
    2 gauge pod from summit. $20. I'd like to get an A-pillar gauge, but not sure which one fits my gen truck.
    So that comes to ~340. For a complete total of $2215. Still cheaper than just the reman transmission from Ford!! I'm going to have to work another couple weeks to get the cash, but I'm pretty sure this is the route I'm going. Thanks for all the help guys
  10. rrogers
    why dont you do the swap yourself and save?
