Truck got busted into last night, alarm advice?
Discussion in 'F-250 and F-350 General Tech and Info' started by Bdons-SD, Jan 29, 2013.
  1. Roush PSD Interceptor
    It is manual. I have to shift from P to D.
    :poker:
    Now I know my next F250 mod, lock box.
  2. Bdons-SD
    Probably going to order that tonight while I look up security systems. Any lock box will probably due, as long as its the right dimensions
  3. Bdons-SD
    My dp tuner has a no start option, so I just set it to no start and take my controller. It's only the size of a key fob.
  4. UtahFord
    Viper man best buy I hear has cheap install
    Sent from my PC36100 using Tapatalk 2
  5. Tareed94
    Tareed94 Member
    College Station, TX
    Mine was broken into a few months ago. Trick with mine is they pried the glass to break it and never opened the door. If you're for sure getting an alarm system make sure to get the window sensor. I found that viper had good systems with remote start on amazon and eBay for pretty cheap.
  6. VanoFord
  7. Bdons-SD
    Hmm... Not bad. Ill let you know. Thanks dude!
  8. iowaredneck
    Hell of a deal
    sent from area 51
  9. UtahFord
    Hell if anyone busted into my truck they wouldn't get much unless they took all my straps and jumper cables.
  10. Bdons-SD
    Normally i don't keep anything of value in it, but we were at the gym and figured it would be safer in the truck than a locker. Wrong!
